| Thread Tools | Search this Thread |
#5351 |
Formerly Thanh1973
Top is 35V rails
Bottom is 40V rails Bias 2.2A Probably a good compromise.
"No, this sucker's electrical, but I need a nuclear reaction to generate the 1.21 gigawatts of electricity I need." |
#5352 |
Aint that sweet
If you are 100% certain those Toshibas are the ones we go fore I will set in motion asap Last edited by tinitus; 26th October 2009 at 04:12 AM. |
#5353 |
Formerly Thanh1973
Maybe hold off here, Nelson or someone else might have some more ideas about this one.
There is another benefit here, it looks like the cascoded version has about another 20dB improvement in PSRR
#5354 |
Formerly Thanh1973
The other alternative is, if you don't exceed 30V rails then you won't need cascode operation.
You will also be able to bias higher.
#5355 |
OK, I got a bit excited
30V would be perfect too We will see how it goes Thanks Thanh |
#5356 |
I'm running 32V on my F5 with 1.2amps bias.
I have had them running since March with no problems. |
#5357 |
Formerly Thanh1973
Yes 32V is fine, you could probably also go to 35 Volts without issues.
But it is good to allow some safety margin.
#5358 |
Might look like this
One channel Not finished Semi hardwired Last edited by tinitus; 27th October 2009 at 01:27 AM. |
#5359 |
Formerly Thanh1973
So is that 4 output pairs I see.
Will the supply be in a sepparate case?
#5360 |
4 output pairs, yes
But I might go up to 6 pairs Supply is on the picture Just the trafo is in an integrated wooden base below heatsinks Supply caps and bridge(double) above trafo NPN and PNP outputs on each side on their own respective heatsink Its a mono amp you see Caps etc is in a inside box to shield from heat I expect it to give very effective convection cooling on inner side of heatsink The hot air that goes upwards along inner side will enhance airflow on the outside as well Last edited by tinitus; 27th October 2009 at 01:55 AM. |
| Currently Active Users Viewing This Thread: 4 (2 members and 2 guests) | |
| Dennis Hui, Bksabath |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| Page generated in 0.21421 seconds (65.02% PHP - 34.98% MySQL) with 11 queries |
