F5 power amplifier - Page 521 - diyAudio
Old 16th October 2009, 07:46 PM   #5201
alazira is offline alazira  United States
alazira's Avatar
Originally Posted by Beftus View Post
You can use IRF9240P's and IRF240N's instead.
Originally Posted by Nelson Pass
The output MOSFETs are the IRF240 N channel type (Q3) and the IRD9240 P channel type (Q4). They will want to have a voltage rating in excess of 50 volts, a current rating of about 15 to 20 amps, and a dissipation of about 150 watts. Comparable parts are widely available, and here I used Fairchild FQA12P20 and FQA19N20C.
This is indeed what it says under the F5 manuel under "Parts Selection." However figure's 5 & 6 show Q3 to be the P channel, not N. Be sure to follow the Figure.
Old 17th October 2009, 05:52 PM   #5202
sekess is offline sekess  United States
Default power supply configuration
Is there a preferred power supply configuration between the following two:
CLCRC or CRCLC ?
Or do they yield similar results?
Thanks,
Steve
Old 17th October 2009, 05:55 PM   #5203
wildburro audio
d to the g's Avatar
CLCRC or CRCLC ?
Thanks,
Steve
Steve,
I would suggest downloading PSUD (its free!) and start simulating your power supply. The program has a shallow learning curve, and gave me a better understanding of power supply component interaction.
d
Old 17th October 2009, 06:01 PM   #5204
Hey d to the g,
I've downloaded that pgm. I couldn't get it to simulate dual rectifiers like I have in my setup (like Nelson's power supplies).
I'll have a look at it again.
Thanks,
Steve
Old 17th October 2009, 08:30 PM   #5205
bobodioulasso's Avatar
Originally Posted by d to the g View Post
Steve,
d
Would you have a link?
Old 17th October 2009, 09:43 PM   #5206
Default softwaer link
Hi bobodiouiasso,
Software
then click on PSU Desogner II
Later,
Steve
Old 17th October 2009, 09:45 PM   #5207
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
Duncan's Amp Pages
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 17th October 2009, 09:52 PM   #5208
Banned
PSUD2
Old 17th October 2009, 10:04 PM   #5209
Default Psu ii
Being that Duncan's nprogram was brought up, I'd like to ask the following:
Does anyone know if it is possible to insert a double bridge in the circuit like the standard First Watt supplies?
I only see that a single solid state bridge is available for analysis.
Thanks,
Steve
Old 17th October 2009, 10:15 PM   #5210
Zen Mod's Avatar
make analysis with just one secondary ;
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Copyright 1999-2017 diyAudio
