| Thread Tools | Search this Thread |
#5151 |
IIRC some Perreaux amps were also SMPS-based. Specially some of their best ones.
The well-regarded MiniWatt also uses a SMPS - and it's a tube amp with only 2.5 watts, so one assumes super-sensitive speakers will be used, ones that would tell tales of power supply noise if there were any. |
#5152 |
Formerly Thanh1973
I think there is real merit in trying to improve the performance of switch mode power supplies for audio use. The big benefit I see is the high efficiency.
While I agree shunt regulators offer pretty spectacular performance, trying to implement one for a class A amplifier can be a real pain in terms of the amount of heat that is dissipated. The heatsinks required can be as large as those used in the amplifer itself. If you look at some of the reviews these days on top quality pc power supplies (switch mode of course), you will notice they have improved tremendously. Seasonic, while manufacturing their own brand of powersupplies, also manufacture power supplies for the best brands in the business. A lot of them are capable of 1000W, the only problem is they don't have the necessary output voltages for amplifiers. I am sure though, some bright spark around here would know enough to mod them to produce the voltages we are interested in. Last edited by Melon Head; 13th October 2009 at 12:38 PM. Reason: punctuation |
#5153 |
Don't almost all high power car amps (some of which are good) use SMPS? They can be very quiet and clean if filtered properly.
#5154 |
The main drawback is that SMPS are not really easy to DIY.
#5155 |
Apologies if this is an irrelevant post due to previously covered topics, but how suitable would the attached regulated power supply (based on the zen v3 regulator) be for use in an F5?
#5156 | |
To be honest I was a little surprised when the question was posed but was equally curious to see what might come out of the community of extremely bright folks that hang around here. Chris |
#5157 |
You can see among Babowana's posts as i know he has built one and opened a thread at this purpose.
#5158 | |
Formerly Thanh1973
To get a feel for what is achievable have a look at the link Seasonic M12D 750 W Power Supply Review | Hardware Secrets Have a look at figure 19 and 20. 23mV p-p of noise isn't great but it isn't bad either, espescially when you consider this is the level of noise at the maximum specified power output (ie 750Watts) of the power supply. Things improve quite a bit when you operate them at less than 100%. Last edited by Melon Head; 13th October 2009 at 09:07 PM. |
#5159 |
Formerly Thanh1973
Now, consider what could be achieved if we put our own CLC or CRC (or even pure capacitor smoothing) power supply at the output.
It would not be very difficult to reduce that 23 mV p-p noise to below 1 mV p-p noise, and that is at 100% of the rated power output of the switchmode power supply. Now to put things further into perspective, consider what would happen if you tried to run a 750VA transformer at 750W continuous. I have never tried this but I know it wouldn't be pretty. Using Nelsons rule. To run 750 Watts continuous you would need a 1500VA (1.5 kVA) transformer, as a bare minimum. Now, a 1.5 kVA transformer is not cheap. I think if we want to seriously consider this furher then we should start up a new thread dedicated to it. Last edited by Melon Head; 13th October 2009 at 10:32 PM. |
#5160 |
In my world its more simple
ClassD needs a very fast supply ClassAB also needs a fast supply, but less ClassA is on continiously and doesnt depend as much on such a fast supply Switcmode seems ideal fore classD, yet some who have tried both switchmode and ordinary supply with big trafo on classD have stated that traditional trafo and caps sounds better Switchmode is cheap, light and small, if thats what your priority I am though very careful not to put too much weight on such statements I might consider THELs regulated supply in his new symmetrical version, takes AC directly Though, I still remember mr Thel himself writing that traditional oldstyle supply being the best sounding, if you dont need the voltage regulation When a man who makes his living selling regulated supply designs say he favours traditional supply, then I tend to believe the man Sure, might be nice to have the option to be able to change supply voltage easily Issues does a regulated supply still need a big trafo, or would it work juast as well with smaller trafo ? Burning 100watt continiously or maybe more, would such a regulated supply get very hot ? Last edited by tinitus; 13th October 2009 at 11:01 PM. |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Jack C. |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.22187 seconds (63.43% PHP - 36.57% MySQL) with 11 queries |
