Old 8th October 2009, 08:33 PM   #5121
cviller is offline cviller  Denmark
cviller's Avatar
Hi dave,
Sounds like a nice big project to keep you busy and warm during the winter!
If I were you I think I would build 6 channels in three boxes - then you can use them for other purposes later.
The 45VAC doesn't sound perfect for this you need to get your rails down to ~2x23V.
I have started a blogged guide to my F5 boards read it here: F5 pcb v2 blog
Old 8th October 2009, 09:23 PM   #5122
tinitus is offline tinitus  Europe
Originally Posted by scranton View Post
I reversed channels and disconnected signal and output and the transformer still buzzed after warmup.
Ok, though it was aimed at the humming speaker. Did you check that
8-10 mv around zero (Is negative DC offset an issue?)
Nothing wrong there
I adjusted slightly to keep offset above zero.
I do think I have two problems: instability due to earlier mistakes and a transformer.
Maybe not. Did you check your signal wires, and ensured that they are away from supply lines. I think it has been suggested to use only shielded signal wire
You may have missed it, but it was suggested to try and decouple transformer mechanically by using rubbers. I may be enough to make the buzzing inaudible, and its cheap
Old 9th October 2009, 01:13 AM   #5123
alazira is offline alazira  United States
alazira's Avatar
Default N&P channel mismatch
Nelson Pass from Post 169 FirstWatt J2 thread:
The IR P channel parts have higher distortion. You could use
the Fairchilds, or take a look at Toshiba or Harris (if you can
find them).
The N vs P channel mismatch is a small source of distortion
down around a watt or so, which is why you want to be
able to trim the Mosfet Source resistors values a bit (if you
have the analyzer handy). Also, it is effective to use a
couple hundred ohm pot, wiper grounded, connected across
the Sources of the input JFETs and trim for least distortion at
1 watt.
Hi Mr. Pass,
This was on the J2 thread but thought I'd ask here for the sake of relevance. Were you referring to trimming R11/R12? As for the 2nd part is my sketch correct? Not that I have anything to analyze with but perhaps I'll look for something on eBay if it seems worthwhile.
Old 9th October 2009, 02:29 AM   #5124
The one and only
Nelson Pass's Avatar
I meant the 3 watt resistors on the Sources of the power
Mosfets going to the supply rails.
And yes, your drawing would be correct.
Either approach works - the pot is more convenient.
Old 9th October 2009, 04:33 PM   #5125
Ok, though it was aimed at the humming speaker. Did you check that? No I didin't. But good tip.
? and Nothing wrong there What I mean here is I raised the offset since, if set to zero, it would cycle between +4mv and -4mv. Raise it to 8 or 10 and it stays zero or above. As a novice, I take things literal.
Maybe not. Did you check your signal wires, and ensured that they are away from supply lines.Yes. And shielded.
RubbersDidn't have any. Used speaker dampening stuff. And loosened it. Did reduce the amplification of the buzzing but it still buzzed.
Have all the resistors in a new board. Add the rest of the parts tonight. Test tomorrow to see if I had one problem. Thanks for all your input.
Q: Is transformer buzzing alright if I can isolate it and make it inaudible?
Old 9th October 2009, 04:36 PM   #5126
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Scranton, My F5 trannies have a tiny buzz to them, but it's not audible through the speakers, only if your standing a foot or so away from it.
SemiSouth R085/R100A JFET available now
DCB1/BiB #3 on order : SSHV2 Sign up Sheet/Payup Sheet Ends 2-26-2012 CLICK HERE
Old 9th October 2009, 06:07 PM   #5127
transformer hum can be worse if excessive AC non symmetric waveform are passed (=AC + DC).
This can be alleviated by fitting a DC blocking filter to the mains fed primary circuit.
regards Andrew T.
Old 9th October 2009, 09:18 PM   #5128
alazira's Avatar
Default adjustments
Hi Mr. Pass,
Thanks for the reply.
Just to confirm, you are referring to R11&R12=0.47ohm 3watt source resistors, right? It does seem that it would be difficult to adjust this value.
While on this subject, on the last page of the F5 manual it says:
"If you have the equipment to see it, you may find that different gain devices will give you a small peak somewhere just below 1MHz. I have found that you can trim this by playing with the values of R13 and R14, but as both values approach 0 ohms, you are likely to see parasitic oscillations."
Is this also doing the same thing as the afore mentioned adjustments? It continues:
"You can additionally limit frequency response with an input capacitor across R10, and also in the feedback loop with capacitance across R5 and/or R8."
Approximately what value caps are we talking here? I've read this whole thread and I don't recall anyone mentioning that they did this. If anyone has, please comment. The only thing said about adjustments was Than1971 in a post about fiddling with R1 & R2 to increase/decrease 2nd/3rd harmonic.
Garrett
Old 9th October 2009, 11:43 PM   #5129
The one and only
If you have a scope and/or distortion analyzer, then you
can play with this. Try different values, starting with values
close to the stock values and see what you get.
Old 10th October 2009, 12:10 AM   #5130
my Naim amps did this quite frequently.
i placed an order for a 18+18 500VA TX from SumR. the other TX i have from Richard is dead quiet. not terribly expensive at $98 either. the PS will be in a separate chassis a la Naim for possible future Pass recipes. i've opted not to go down the bridged amp route for now - it's time i started playing around with FR drivers.
heatsinks arrived today too!
Currently Active Users Viewing This Thread: 5 (4 members and 1 guests)
extrip, arche13, brainf, c_door
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.20156 seconds (67.88% PHP - 32.12% MySQL) with 11 queries
