| Thread Tools | Search this Thread |
#5101 |
Baby Danika, Born January 20th 1:54am.. http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect.. |
#5102 |
Formerly Thanh1973
Have you tried it?
This is what all the manufacturers use. If you want better then polyurea or polyurethane would be better. If you want to improve on that then fill it with very dense pigments. |
#5103 |
I have poted one into an aluminium pan using silicone. That made it silent but i do not know about the long time.
#5104 |
Formerly Thanh1973
Silicone has some nice properties, as good as or possibly better than polyurethane
#5105 |
Heat sinking might be an issue?
It coud become a torrid transformer. |
#5106 |
For potting a transformer, use the special compounds developed for potting- available from most professional parts suppliers, an nusually not more expensive than the amount of epoxy required.
Vacuum impregnating the core/windings of a trafo is something else - this is done with very low viscosity laquers to get into the windings. Can't be done with normal potting compounds....
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals! |
#5107 |
Labjr: Which transformer are you using?
Hi The Avel 250va 18v + 18v dual secondaries. It had been working fine. The same transformer in the other monoblock is working. I do have a very slight hum in that speaker, but it doesn't change when the transformer starts making the noise. Thanks for your repllies. Even with this problem the F5 is performing very nicely. |
#5108 |
Does one chassis buzz more than the other one if you put your ear to it?
I don't know if a noisy transformer will make a hum through the speaker. Maybe someone else can answer this. |
#5109 |
Just the one transformer buzzes. I can hear it faintly from 3 feet away. And that unit's speaker has a very minor hum that I can only hear withmy ear on the thing and I hear it from start up. The transformer develops the buzz an hour after startup. The other monoblock makes no chassis noises and the speaker is perfectly quiet.
About this time I did do a mod on my cd player. Bypassed the output caps per Kit Ryan's . suggested mods in Audio xpress. Could this be related? Cd is attached to B1 that is attached to F5. Thanks for help. |
#5110 |
You could try disconnect your signal/B1, to see if it still hums
Or reverse channels from your signal/B1, to see if it follows signal Also examine if wireing is slightly different on left/right channel Your hum and buzz might still be two different things Nelson have said that hum might be an indication of minor instability And that it may be related to signal wire/grounding As said earlier, even the slightest transformer buzzing can be "amplified" by the enclosure, and sound much worse Without the box you might not hear anything edit, do your supply caps get hot ? Last edited by tinitus; 7th October 2009 at 08:35 PM. |
| Currently Active Users Viewing This Thread: 5 (4 members and 1 guests) | |
| extrip, arche13, brainf, c_door |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.19394 seconds (63.46% PHP - 36.54% MySQL) with 11 queries |
