| Thread Tools | Search this Thread |
#5091 |
Aww, gee, thanks. I abandoned the test as the thermal transfer was terrible, I'll try the real amps to check it out - once I get my head down and build it up. I now have pretty much everything I need to build it except the solid teak logs for the chassis...
#5092 |
try gluing the thermistor to the drain lead right next to where it exits the package.
regards Andrew T. |
#5093 |
Hi
GOt the F5 working very nicely about a week ago with the generous help of members. The day before yesterday I was hearing a very slight buzz from one of the chassis. Last night it was a bit louder and I thought was coming from the transformer. I tightened down the screw and this morning after 1/2 hour warmup and then listening for 1/2 hour, I noticed it again. Is this oscillation? I don't have any filtering on the inputs. I can install that tonight. Is this coming from the transformer? Thanks Jan |
#5094 |
I had the same problem recently, and I just loosened the mounting screw, and problem solved
Point is that even a very small and inaudible buzzing can set the whole box in vibration And THAT can be very audible Might not be good fore the electronics either You could try and mount some soft rubbers underneath the trafo, and between trafo and mounting plate, and tighten it loosely Actually I try to avoid using the metal mounting plate, and use brass screw, but thats a different story Anyway, as far as I understand F5 may be sensitive to interconnects |
#5095 |
Sounds like lamination buzzing as the windings heat up. Not much you can do. The better transformers are dumped in a pressure lacquer tank for a few days before being covered and sold.
#5096 |
If that's what it is, I thought it could be fixed by potting. I've never done one myself. But, I think I read somewhere around here that it can be DIY.
However, I don't know specifically what potting material to use or where to get it. Steve |
#5097 | |
#5098 |
I think i might jump in on this bandwaggon
Quesitons tho. Psu voltage per rail ? I think im running 18V on my mini a's will this work ? will be good with Mini a's? Going to use with ribbon tweeter.
Baby Danika, Born January 20th 1:54am.. http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect.. |
#5099 |
Not too sure about the 'potting' of a Txformer after the fact. You need to uncover the winding cover sheets and somehow find the right potting compound. I have no idea what that stuff actually is, but it'd need to be something that can't attack the enamelling over a long period and also not become porous or affect the dielectric poroperties of the enamel.
I'm sure a transformer winding outfit could help you. |
#5100 |
Formerly Thanh1973
| Currently Active Users Viewing This Thread: 4 (3 members and 1 guests) | |
| rothay, hofer |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.21749 seconds (69.60% PHP - 30.40% MySQL) with 11 queries |
