Old 29th April 2008, 10:52 AM   #501
TimS is offline TimS  New Zealand
Originally posted by jameshillj
Anybody, looking for a 15H (not mH!)/ 350mA+/ <15R choke for the L-C supply - any ideas?
What is its rated voltage? It sounds like its for a valve B+ supply filter.
Old 29th April 2008, 11:32 AM   #502
Yeah Tim,
Have rewired the 701s (Z=63R) and using an "unbal - bal" adapter that also includes the adjustable series resistors (varies with different amps unfortunately).
[Amazing sound connected directly to o/p of F3 (as unbal)]
Estimate about 350mA thru the 610/9610 fets, and about 5mA thru the Jfets.
Expecting some pcbs for a mini Babblefish J (from ZM) as an upgrade to Marchello Originals [also approx +/- 15v rails].
... Thanks.
Here is your amp, almost to your specs, I had to run the final bias a little higher (477mA) so it could drive its own feedback resistors and still keep the distortion low.
Now where shall I send the bill...
Cheers
Tim
File Type: png balanced f5 preamp with j74 and k170.png (24.4 KB, 3261 views)
Old 29th April 2008, 01:19 PM   #503
Thanks Tim,
That sim program of yours saves an enormous amount of time, particularly with such an intriguing small "bunch o' bits"!
So, Rails of +/- 12volts, about 500 mA X 2 per channel = 24VA per channel - nice and solid, eh - no "toys"!
It will be interesting to hear how the different supplies effect the sound.
Should all those common connected Jfets have small isolation gate resistors?
Chokes: Most of the large size commercial ones that I've found are higher voltage units made for valve gear and the usual "large L, small C" designs have been for preamps and such - this load [1/2A X 2] doesn't fit into this category at all.
Is there such a thing as an "L multiplier"?!
About the bill - what do you need that we may have over here? [Apart from the AudioX which isn't available here, yet!]
Appreciate your time & effort - thanks again.
... jh
Old 29th April 2008, 01:50 PM   #504
Originally posted by Nelson Pass
If you Google "Fistwatt", you will get 9 references.
Argh, Freud you know.... but luckily i'm not the only one as googling FistWatt proves it...... ;-) Ant most of them are about YOUR product....
Anyway, did you get a free lunch with all of those more ??
There must be a price to it.
F1 rocks the bottom part of the sound spectrum, how does F5 compare to ? F3 is a close tube like sound, is F5 more classic Class A or more Class A like F3. Regards
Old 29th April 2008, 05:05 PM   #505
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Nicola,
speaking of Ziggy's-Mund, did you know your posts always come in matching pairs, and you are the Two-and-Only with this reaccuring phenomenon ?
Looks like Sponge Bob has killed another thread.
Old 29th April 2008, 05:45 PM   #506
Red face Matching pairs
Originally posted by jacco vermeulen
Nicola,
Matching pairs but unfortunately not matched pairs ? Would have been rather nice in such forum. Wwell schizophrenia does not help. ;-). Seriously, never noted this phenomenon, unless that occurs only on some computers..... argh,,,,, (how many pairs of this now ??)
Old 29th April 2008, 07:26 PM   #507
The one and only
Nelson Pass's Avatar
I would say not quite either.
Old 29th April 2008, 08:29 PM   #508
Brett's Avatar
Originally posted by TimS
Ma get me my gun..
Y'see, I'd only just finished watching the NZ movie masterpiece "The Devil Made Me Do It".
Old 29th April 2008, 09:58 PM   #509
Thanks Tim,
You can add the small gate isolation resistor if you want.
Just a Biasing and Testing notes:
Test and bias each side with the the 15R resistors disconnected. when the sides are biased matched and tested then connect the 15R resistors.
You will have to tweak the biasing because your JFETs will be different from my sim JFETs. Make R134 R148 R102 R139 a 1k resistor in parallel with a 1K trim pot + 4k7 resistor.
Make sure the bias currents are identical between the left and right sides before connecting the 15R resistors.
Try to match the left to right sides of the amp as well as the top to bottom.
Don't worry about the the supply voltage will not effect the bias currents too much.
This amp is -3dB at 1MHz so be careful with your circuit layout and shielding.
If you want to change the gain, change R137 and R131. The circuit gain is (R150+R136)/R137.
[/NOTE]
If you could help me find some JFETs it would be much appreciated.
Cheers
Tim
Old 30th April 2008, 01:23 AM   #510
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Default F5 as populist amp
I completed the AX article. I loved the intro about gates and drains and water pipe references.
I suspect the fistwhat F5 will become a very popular DIY project.
It's got a small parts count, less power fets, and reasonable gain and output. It's not as strange by design as the others IMO. The 25W RMS makes it a popular replacement for the GainClone crowd, assuming the sound is anything like the F4 from reviews.
If Nelson sticks to his word (or my interpretation of it), than the next few are repeats with more power as monoblock projects, and the cheapskates may be left behind, or at least listening in mono.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Oreda, ce
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.20001 seconds (54.26% PHP - 45.74% MySQL) with 11 queries
