Old 26th September 2009, 12:55 AM   #5001
The one and only
Nelson Pass's Avatar
Originally Posted by Zen Mod View Post
using shottky can't do any harm
fact is that Papa is using them in Pass Labs products
Actually we are using fast/soft recovery types
Old 26th September 2009, 06:57 AM   #5002
Originally Posted by Lucas_G View Post
Now that is a very good tip! Thank you!
Being a greedy Dutchman, I will write to them in English. I hope they will answer...
Has anyone ordered with them from abroad? How smooth went the transaction?
would you get a quote
I like to buy toroid for F5 as well Aleph XJ
Old 26th September 2009, 01:15 PM   #5003
Lucas_G is offline Lucas_G  Netherlands
I did not receive an answer yet (It's weekend in Poland) ,but I will let you know when I hear from them.
BTW, I have got some large an new toroids with 30V on the attick.
I bought them for some extra Alephs (I did build an Aleph5 - splendif amp!), but never found the time to built those extra pairs.
If anyone is interested in buying these, drop me a mail...
Lucas
Old 26th September 2009, 01:17 PM   #5004
Nelson, did you have a preference for a certain type of diode?
Was the difference in sound quality obvious?
Lucas
Old 26th September 2009, 03:01 PM   #5005
tinitus is offline tinitus  Europe
I used this
Hyperfast and fast recovery, which I didnt know about back then
Appears to work ok though, since amp sounds nice, and beats many around
But now I wonder if I should try "soft recovery" types
https://www1.elfa.se/data1/wwwroot/w...A/07023393.pdf
Bridge is mounted on sides of heatsink
I would NOT do that with classA
Hope picture will change to F5 next time
Old 26th September 2009, 03:29 PM   #5006
jackinnj's Avatar
I have used MUR860's and HexFred diodes...ashamed to admit I can't tell the difference.
Old 26th September 2009, 07:06 PM   #5007
Nothing to be ashamed of - maybe both are quite good at it.
I was wondering whether the MUR 860 (I have got bunches around) is up to the task for 2 channels of F5. They are specified with 8 A maximum. Is that enough safety margin for this application?
I have also got spare PCBs of the CarlosFM PSU here that uses these MUR 860s. I could use them together wit Civiller PSU boards in a CRCLC configuration, if they could stand the current draw. Can anyone advice on this?
The IR 30EPH06 used by Tinitus is of a totally different caliber. It is rated with 30 A. Has anyone else experience with these?
Old 26th September 2009, 07:17 PM   #5008
Originally Posted by tinitus View Post
I used this
Hi Tinitus,
In the PDF it says:
"State of the art Hyperfast recovery rectifiers designed with optimized performance of forward voltage drop,
Hyperfast recover time, and soft recovery."
So maybe you have made a better choice than you realize
BTW, do they get warm?
Old 26th September 2009, 07:40 PM   #5009
Hi Tinitus,
I didnt see the soft recovery, so you saved me there, thanks
No, they dont get hot
Or, as hot as the heatsink the outputs are mounted on
I have driven a 1ohm speaker, but it definately liked 2ohm better
Its a 50wat, so could ad up to considerably amount of current
I dont know, but F5 is not designed to deliver huge amounts of current
Might help if you use double bridge on each channel
May depend on the heatsink, or whatever you choose to mount them on
Maybe power-up is the worst possible situation
But really, I dont know how much current flows in each diode of a bridge
But basicly it shouldnt be much more than bias current, and use the original curcuit with limiters
And maybe save a bit an trafo size
And, depending on your speakers
But again, power-up could be the most critical situation
But personally, that may not be where I would save money
Old 26th September 2009, 08:13 PM   #5010
ichiban is offline ichiban  United States
space charged
ichiban's Avatar
I'm wondering if the F5 would be up to the task of driving Strathearns
one half ohm resistance if the amp only high passed 300-500 Hz ?
First order input filter on F5.
Anybody?
Currently Active Users Viewing This Thread: 7 (4 members and 3 guests)
zephyr, UKToecutter, Jack C.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.26794 seconds (42.66% PHP - 57.34% MySQL) with 11 queries
