Old 24th September 2009, 10:39 PM   #4971
Banned
I am now seriously considering doing monoblocks with this amp.
So P Channel and N Channel output mosfets will be on sepparate heatsinks (ie on each side of the amplifier case).
Will there be any problems in doing this?
I guess this is what is done in the XA 60.5 monoblocks. So it should be doable.
Any advice on this would be appreciated.
Old 24th September 2009, 10:54 PM   #4972
Beftus is offline Beftus  Netherlands
Beftus's Avatar
Originally Posted by Lucas_G View Post
I live in the Netherlands and there are not so many options for transformers to use in the F5.
Check amplimo.nl. They offer 300VA, 500VA, 625VA, 800VA toroids with twin 18V secondaries. 500VA should be enough for a F5. Can be bought online @ deaudiofabriek.nl. Success!
Old 25th September 2009, 03:05 AM   #4973
sangram is offline sangram  India
I'm doing exactly the same thing, except mine will be uncased.
Peter's F5 is built like this as well, and his PCB is perfect for such a task as the devices are facing each other on the opposite sides of the PCB. Of course I will be running open chassis so the ~2" width of the entire assembly does not bother me.
Andrew posted some open questions regarding this arrangement, specially as the output offset depends on the temperature/operating point balance between the two halves and separating them like this means they can't 'talk' to each other. Peter uses a metal sheet to connect the two halves. I'm still wondering what to do, but probably I'll have a thick sheet of aluminum as the 'front panel' connecting the two halves, sliding into the slot on the heatsink.
Old 25th September 2009, 03:16 AM   #4974
jackinnj's Avatar
Originally Posted by Nelson Pass View Post
Nice chassis. Did you make it yourself?
They were offered out by another diyaudio-r, and I haven't see 'em in quite a while --
My usual amplifier box is recycled Hewlett Packard or Kepco power supply,and my heat sinks are military or industrial surplus. Because of WAF I use Audio Research in the public rooms of the household.
Edit, the listening room isn't public -- it has a Grizzly mill, an AP analyzer, my modified Thors, a pair of TM5006 mainframes, solder and rework stations, Heath power supplies, HP HV power supplies, a new sony CD/SACD player, tuner which (by intent) only receives AM radio, much-modded Adcom GFP565, a beat up Acoustic Research SP-11, and of course several F4 and F5 amplifiers.
Old 25th September 2009, 03:20 AM   #4975
The one and only
Nelson Pass's Avatar
recycled HP is class. old HP
Old 25th September 2009, 09:44 AM   #4976
nicoch58's Avatar
HI Pass
the chassis look like http://diyenclosures.com/products/chassis/diy1013/
as I have one pair
Old 25th September 2009, 09:55 AM   #4977
Jaac is offline Jaac  Netherlands
Jaac's Avatar
I've recently bought two 300VA 2x 18V toroids directly from the amplimo site. Emailed the guy if he could pot them into metal cans. And they do, that it looks very nice i will post some pictures later on.
The right tool for the right job, a very nice Solarboat || Ready for a groupbuy ? CLick
Old 25th September 2009, 10:03 AM   #4978
Here's another source for transformers:
http://www.toroidy.pl/index.php?opti...id=6&Itemid=13
They have a range specially made for audio, good prices too.
Old 25th September 2009, 11:36 AM   #4979
how much cost additional center potting
Is there Interest at toroidy If so I will buy 1 or 2
Old 25th September 2009, 12:30 PM   #4980
I have used a couple of their transformers in my Patak style gainclone - they work extremely well; however in the UK we are now at a disadvantage (GBP vs EUR), but elsewhere in Europe I expect their prices are still good.
Ps these are the transformers I believe PD uses for his own Pateks (apologies Peter if that is not the case)
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2013 diyAudio
