F5 power amplifier
F5 power amplifier
Old 28th April 2008, 12:26 AM   #481
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 power amplifier
Originally posted by Nicola
Thanks Mr Pass, look forward to read it, hopefully there will be soon also article like the 6moons or by J Lowther to get a taste of the quality and listener differences between the several models. But may I ask you how would qualify / compare F5 to F1 or F3, if I may.
By the way, do you plan to build & sell some through RenoHifi?
I am not planning a write of up the subjective differences between the
models, but Srajan at 6moons will undoubtedly offer his own opinion.
They will be available from Mark@renohifi shortly, although I probably
should tell him about it.
There will be a short piece on tweaking F5's, and then the next major
article is about buffers.
Old 28th April 2008, 06:16 AM   #482
EUVL is offline EUVL  Europe
> I have two (balanced) versions .....
> There will be a short piece on tweaking F5's ....
We all keep our plans on hold then !!!
Patrick
Old 28th April 2008, 10:37 AM   #483
TimS is offline TimS  New Zealand
Default High Power Balanced F5
To run the amp at a higher supply voltage, as some one suggested, I tried cascoding the input JFET's but I really couldn't find much advantage. I find just adding resistors fixes the problem and the performance is almost identical.
I think this is my last iteration of this design, I have tried many other variations with not much improvement in the performance. Though I may scale the design down for a preamp.
I think my next step will be to build it. I have the heatsinks, the transformers and most of the metal work for the case. I just need to design a board and find some JFETs.
Cheers
Tim
Old 28th April 2008, 10:51 AM   #484
jameshillj is offline jameshillj  Australia
Tim,
While you're at your computer, could you possibly scale this cct down to drive a pair of headphones from 32R (grado ) up to 600R (Senn), with matched pairs of k170+j74 and 610+9610? And still have Zin of >100kR?
Old 28th April 2008, 03:16 PM   #485
jackinnj is offline jackinnj  United States
jackinnj's Avatar
F5 power amplifier
F5 sans inquietude thermique:
Old 28th April 2008, 04:43 PM   #486
Nicola is offline Nicola
Default Subjectivty on F5
Originally posted by Nelson Pass
I am not planning a write of up the subjective differences between the models, but Srajan at 6moons will undoubtedly offer his own opinion.
There will be a short piece on tweaking F5's, and then the next major article is about buffers.
Some "subjective differences" are more subjectives that others
& i'm pretty sure your comment are factuals. But so far is there some spec that provide an indication on power, damping factor, distortion, as you have been writing on F2, F1, none of them where that subjective.
"and then the next major article is about buffers" avaialable under FistWatt.com ?
Old 28th April 2008, 07:34 PM   #487
Originally posted by jameshillj
Tim,
I could probably do that, I could make it a preamp that is able to drive headphones, but do you realize, you would have to cut the plugs off your headphones and replace them with a 4 pin plug.
Old 28th April 2008, 09:49 PM   #488
The one and only
F5 power amplifier
Default Re: Subjectivty on F5
FistWatt. I like that.
Suffice it to say that the F5 has more power, more damping,
more current, more bandwidth, lower distortion, and higher
input impedance than the other F's. Many will think it sounds
better.
Old 28th April 2008, 09:52 PM   #489
SCD is offline SCD  Canada
Hmmmmm
Bigger, better, stronger, faster. All the good things in life
You got to like that.
What about lemony fresh?
Why does AxP take so long to get to my house
SCD
Old 28th April 2008, 10:06 PM   #490
The one and only
F5 power amplifier
If you Google "Fistwatt", you will get 9 references.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
