Old 13th August 2009, 12:55 AM   #4771
Formerly "jh6you". R.I.P.
Babowana's Avatar
Originally posted by vdi_nenna
I take it my calcultion is wrong above?
No, nothing is wrong in the calculation of converting RMS voltage into peak value. I have, however, thought about "each bridge sees only one secondary which is 18VAC [=18Vrms]" . . .
BTW, this would be an interesting reading about bridge rectifier.
Old 24th August 2009, 06:17 AM   #4772
Formerly Thanh1973
Melon Head's Avatar
Default High Bias Current (4A) Version
Here is my high bias current version (4 Amps) of the F5 using 3 output pairs.
It is also the first time I have done a point to point circuit using perf board (I hope all goes well).
I still need to solder the output mosfets.
Well I hope this encourages others to try out this amp.
I should have this up and running by the end of the week.
Old 24th August 2009, 07:02 AM   #4773
chinsettawong's Avatar
Wow! 4 amps! How much power do you expect the amp can produce?
Looking forward to seeing your finished amp.
Wachara C.
Old 24th August 2009, 10:22 AM   #4774
Formerly Thanh1973
Melon Head's Avatar
Total power is still the same.
However max "class A" power is increased espescially into lower impedance loads (eg 4 Ohms).
Harmonic Distortion is also improved.
Old 25th August 2009, 08:32 PM   #4775
I've got a question about R21/R22.
Mr PASS says that the value could be from 10K to 22K.
Is there something to modify if using 15K ?
What is affected by those resistors values ?
I'm using FQA12P20 and FQA19N20C MosFets, provided by EUVL (thanks to him).
Thanks for your help
Old 27th August 2009, 01:41 AM   #4776
npapp is offline npapp  United States
Does paralleling output devises also effect the damping? And if so, how do you calculate the damping?
Old 27th August 2009, 12:47 PM   #4777
Formerly Thanh1973
Melon Head's Avatar
Damping factor is inversely proportional to output impedance.
Since their is no resistor at the output which would dominate the output impedance.
Then in theory damping factor should increase (ie output impedance reduce) proportionaly by parralleling output transistors (for this design), Eg if damping factor is 80 for 1 pair then damping factor should be 240 with three pairs.
Well that is how I see it.
Damping factor is usually quoted for an 8 Ohm load therefore DF=8/output impedance.
So for a damping factor of 80 the output impedance equals 0.1Ohms.
If you want to calculate the output impedance (not knowing what the damping factor is) then it is not that straight foward. Negative feedback comes into it.
I use LTspice to determine such things.
Old 27th August 2009, 01:27 PM   #4778
Thanh1973, I am a noobie and i have not yet learn to model on LTspice. Are you going to model the output impedance for your parallel output tranny F5? If so and it is not to much trouble, would you mind also working it out for 2 parallel output trannies.
I am asking because I am currently building an amp with 2 output pairs and 28v rails for 4 ohm speakers.
Thanks,
Nick
Old 27th August 2009, 02:06 PM   #4779
udailey is offline udailey  United States
Passive Aggressive
So what are you using to heatsink this monster?!
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 27th August 2009, 09:47 PM   #4780
Formerly Thanh1973
Melon Head's Avatar
I have built a prototype test set up for the purposes of testing amplifiers. It consists of a flat piece of aluminium which is bent in the shape of a U. On one side is mounted one F5 channel and on the other side I have mounted a Swiftech CPU heatsink and fan (run off a 9V battery). I have a attached a thermocouple to the aluminium right next to one of the devices that will monitor temperature while testing. I also have another thermocouple that I can use to measure temperature difference between each device.
I hope to fire it up for the first time today. I am not sure I will get to 4 Amps using this test setup, but we will see. If all goes well I will repeat some of the test Nelson has done just to see how it performs.
I will also take some pictures.
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
Dennis Hui, Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.20389 seconds (66.28% PHP - 33.72% MySQL) with 11 queries
