Old 11th August 2009, 03:07 PM   #4751
Thank you all for the replies - since I have a bunch of CL6's I will initially try two of them in series on the Neutral feed.
Would it be better (in general terms) to go for twin primaries with the suggested series CL6's between the windings rather a single primary with the sereis CL6's on the neutral line?
I ask as I am about to order some more transformers for the F2.
Alan
Old 11th August 2009, 03:43 PM   #4752
no,
use a single primary where you only have access to a single supply voltage.
Twin primaries increases the cost and possibly the field leakage.
Keep in mind that most transformers are available as 230:Vsecondary, but your supply varies between 216Vac and 254Vac.
You have typed CL6 again.
What is a CL6?
regards Andrew T.
Old 11th August 2009, 04:01 PM   #4753
Originally posted by AndrewT
no,
What is a CL6?
Silly me - should be CL60.
On the mains side I wish people in this country would make the transformers for 240v - at least it would keep the transformer outputs closer to the required values. I usually find that the mains is higher than 240v - cannot say that I have seen very low readings. Either that or have lower secondaries and hope the mains voltage is high.
Thanks for the primary info.
Alan
Old 11th August 2009, 08:04 PM   #4754
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Default Bridge Rectifiers
Is using a bridge rectifier with 50v PIV and 25 amps too small for the F5? The recommended F4 PS schem says 35A 200V.
If we are looking at 18v off the transfo taps, is 50V a safe enough margin?
Thanks,
Vince
Zen, BOZ, BOZ-J, BLS, B1, Mini-A, Audio Sector NOS DAC, Gain Clone, F5, CAT5 Speaker Cable, DIY Allen Wright ICs, MOX II
Old 12th August 2009, 08:31 AM   #4755
Formerly "jh6you". R.I.P.
Babowana's Avatar
Default Re: Bridge Rectifiers
Since the peak inverse voltage is rated at 50V, maximum RMS bridge input voltage is to be no more than 35V(rms). So, I think the bridge questioned is considered acceptable with the 18V(rms) input.
Old 12th August 2009, 10:08 AM   #4756
18+18Vac will develop <=60Vdc across the rectifier in worst case conditions.
Using a 50V rectifier is risky, just as using 25V capacitors is risky.
regards Andrew T.
Old 12th August 2009, 11:21 AM   #4757
h_a is offline h_a  Europe
h_a's Avatar
If the bridge blows, caps may see reverse voltage and may explode in the worst case. Wether your speakers will be happy with the fed funny signal is also hard to say.
If only half the bridge blows (and goes open), you get most likely nice DC at the output.
Believe me, you don't want a blown bridge.
Go for a larger voltage rating.
Have fun, Hannes
EDIT: only blown Schottky bridges are more fun, they usually short.
Old 12th August 2009, 11:55 AM   #4758
vdi_nenna's Avatar
Just a shot in the dark, but I calculated 18+18=36 * 1.414= 50.904v peak.
or 24*=48 * 1.414 = 67.87v peak?
Old 12th August 2009, 01:58 PM   #4759
allow for regulation and allow for maximum mains supply voltage.
regards Andrew T.
Old 12th August 2009, 04:01 PM   #4760
Babowana's Avatar
a shot in the dark . . .
Your doggie is cute . . .
Currently Active Users Viewing This Thread: 5 (4 members and 1 guests)
unixdeveloper, Oreda, rothay, hofer
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.18430 seconds (66.82% PHP - 33.18% MySQL) with 11 queries
