| Thread Tools | Search this Thread |
#4631 | |
Now I just need to find sinks to dissipate 160w per channel |
#4632 | |
The one and only
#4633 | |
Papa oracle, do you see me happy with an F5 in the near future? |
#4634 |
npapp,
You can get huge heat sinks in Switzerland. They offer from 20mm up to 1000mm length. I do not know much about the seller, but this PDF looks interesting: http://www.elinter.ch/media/img/01%2...M-P215-77A.pdf Perhaps you need two of them in full lenght? Sure very expensive to USA, but who knows... |
#4635 |
Dear Oracle,
Does really no one like to explain how those thermistors should be calculated? Post #4604 I'm confused, because you used two of them in your circuit from Power Supply First Watt F3 : http://www.firstwatt.com/downloads/F...-manual-sm.pdf Thanks for sharing. I'm pretty sure you are not interested in this, but i miss something: My Edit Button. Can i get some? That would be enchanting. Regards Sisyphism |
#4636 | |
good sense of humor
natural sound reproduction from traditional dynamic drivers?!! come on.. no no, it can be.. it must be!.. |
#4637 |
Sisyphism,
According to the PDF file one cl60 works for a 300va/230v transformer. The CL60 imeasures 10 ohms@25° and 0,5 ohm@2.5Amp One for each transformer will work fine. The one to ground is usefull too. You cannot make a mistake if you follow the PDF. Your prior schematic was right to my sense. http://www.gesensing.com/products/re...asheets/cl.pdf |
#4638 |
one CL60 works for 110/120Vac 300VA transformer.
For 220/240Vac use try two CL60 in series. I would never expect a CL60 to drop to 0r5 with 2.5A passing on a 220/240Vac mains supply. 2.5A @ 230Vac ~600W passing into the primary of a 300VA transformer.
regards Andrew T. |
#4639 | |
-one cl60 for 220v -two cl60 for 110 v I use one per 250va 220v transformer. I never have blown any 1.25T fuse. |
#4640 |
Hi all,
i gathered 90% of the parts for my F5 Monos only some of the Panasonic 3w resistors and the thermistors are missing but before i order the missing stuff from digikey i have some questions left, maybe you can help me out. 1. What digikey part number to choose for the 4.7k thermistors? They have like a gazillion different types avaible and i am getting confused here. 2. The power supply: I want to go full mono with one 330VA transformer per channel and C-R-C-R-C, but i still have problems choosing the right values for R, C will be 22.000uF 50V Nichicons. So, in the original stereo f5 we have C-R-C, 30.000uF - 0.1175R - 30.000uF Thats for stereo, my amps are mono so there will be only have the current flowing, so I can double the resistance to 0.22R and will still have the same voltage drop, since i want to go C-R-C-R-C i need to split up the resistance equal and end up with 22.000uF - 0.11R (2x0.22R 3W) - 22.000uF -(2x0.22R 3W) - 22.000uF per rail. Should give the same Voltage drop as the original supply and since 12W rating for the resistors is ok for a stereo amp i guess i should be on the safe side using 6W for my monos, , or did i oversee something fundamental? Thanks for your help |
| Currently Active Users Viewing This Thread: 4 (2 members and 2 guests) | |
| Dennis Hui, Bksabath |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| Page generated in 0.19371 seconds (58.60% PHP - 41.40% MySQL) with 11 queries |
