Old 25th July 2009, 08:47 PM   #4601
Thanks bobodioulasso.
I will remember that.
Can i use a 500W Variac? Is this enough power for start up?
On its specs i read 2A max. @ 230VAC.
Old 25th July 2009, 08:48 PM   #4602
cetoole is offline cetoole  United States
I was just getting ready to order parts to build one of these, and both Mouser and Digikey have no stock of FQA12P20 or FQA19N20C, and Fairchild's website shows both on the NRND list. Any suggestions for subs?
Old 25th July 2009, 09:06 PM   #4603
bobodioulasso's Avatar
A bulb is nice to detect a problem at first run.
If all is ok the bulb enlights brievly and go dark again with pots at min.
The charging caps then nothing.
If the bulb stay lighting , switch off, there is a fault or pots are maximum.
I you do not start at a too low voltage, why not to use your variac in a
second time.
Old 25th July 2009, 09:57 PM   #4604
Yes, pots at minimum = Zero Ohm.
First i have to put the PSU into the case,
and there are some questions about thermistors i should use.
This is something I DO NOT KNOW IF IT REALLY WORKS FINE,
How should i calculate those Thermistors ?
TH1 should be ok i think, but how about TH2 + TH3 ?
Please correct me, if there is something wrong.
Old 25th July 2009, 10:02 PM   #4605
nigelwright7557's Avatar
You seem to be using 3 thremistors where one would do the job.
I dont think you need TH1 just connect it to earth for safety.
If you put TH1 in series with mains you dont need TH2.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 25th July 2009, 10:41 PM   #4606
udailey is offline udailey  United States
Passive Aggressive
Those thermistors are calculated for you. Check the bottom of your schematic you posted and it tells values and part numbers for all of them.
When you fire it up you can use your variac but you can use this as well
http://www.antiqueradio.org/dimbulb.htm
This is the dim bulb tester they were talking about and it has saved a few of my amps.
500w is more than enough.
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 25th July 2009, 10:43 PM   #4607
Default PS
I made this file, and it seems to be wrong in some cases.
Old 25th July 2009, 10:55 PM   #4608
Default PSU 230V
If i understand it right, nigelwright7557 thinks this way is ok.
Thanks.
Old 25th July 2009, 10:57 PM   #4609
Default Re: PSU 230V
Thanks.
Yes, providing you can get a thermistor powerful enough to take all the current to both transformers.
Old 25th July 2009, 10:59 PM   #4610
Jozua is offline Jozua  South Africa
Default Comparing a F5 with an Aleph 30
Hi
Has anybody done this comparison ?
I have a Aleph30 that sounds excellent. Would the F5 sound better?
Audio regards
Jozua
Currently Active Users Viewing This Thread: 5 (4 members and 1 guests)
Oreda, baggerbole, ce, unixdeveloper
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.16333 seconds (60.87% PHP - 39.13% MySQL) with 11 queries
