Old 20th July 2009, 06:30 PM   #4551
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Originally posted by fff0
Do you mind showing where you got them?
Thanks.
Yes, I need one too.
Old 21st July 2009, 05:56 PM   #4552
sangram is offline sangram  India
Two questions:
1. If I already had 22V transformers lying around that gave me about 31-32VDC, what is the best course of action:
a. Order new ones anyway,
b. Run the amp at full voltage and back off the bias to keep dissipation manageable,
c. Run the amp at full voltage and full bias, and ensure the heatsinking can handle it, or
d. Regulate the supply rails with a pass transistor (not a pun!) and a zener or two.
Thanks for the input. Hope option 2 looks reasonable. I assume I will lose some power this way, and only get 30 watts or so in Class A. I'm actually OK with that. I will be using 1 c/w heatsink for each transistor, these are heavily finned 10" x 5" TO3 heatsinks (so have a blank mounting area running the length of the extrusion).
Four of these heatsinks will be used, I assume the additional 7 watts of dissipation will not be problem for them even if I ran the amp full tilt.
I mean to check my temperatures for a few days anyway, but would like to reuse these transformers if possible. They are rated to 10A continuous, are heavily overbuilt, and cost me a pretty penny.
I don't want to use regulated supplies if I can help it. The transistor market in India is guaranteed to throw fakes my way, and I'm not cool with blowing up any expensive devices or speakers.
2. I need a wee bit more gain. About 6-8dB will do it. Am assuming opamps will not cut it (I have some LM4562 laying about), any suggestions? I was hoping to build a small tube preamp for these if I could, but need some pointers (not ready circuits, more like a primer on tubes and how to set operating points and gain).
Old 21st July 2009, 06:09 PM   #4553
bobodioulasso's Avatar
The F5 cannot be supplied with more than 25volts.
If your transformers are torroids, you could unwind some of the secondaries
Old 21st July 2009, 06:14 PM   #4554
So it's either new transformers or a regulated supply, then. These are EI, so unwinding is not going to be possible.
Just what I was hoping to avoid, but maybe unavoidable.
Old 21st July 2009, 07:35 PM   #4555
The one and only
Nelson Pass's Avatar
The F5 would ordinarily withstand operating voltages to about
35 volts, although this would probably create thermal limitations.
Old 21st July 2009, 08:09 PM   #4556
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Default Antek Transfos
Just got mine in the mail. These guys are big and heavy!
Don't know if I'll need two! ...but I'm gonna use them both anyway!
Zen, BOZ, BOZ-J, BLS, B1, Mini-A, Audio Sector NOS DAC, Gain Clone, F5, CAT5 Speaker Cable, DIY Allen Wright ICs, MOX II
Old 21st July 2009, 08:23 PM   #4557
Thank you, Mr. Pass
Just the answer I was hoping for, I assume this would mean backing the bias off a bit would help. With the assumption that each transistor needed to be dissipating around 34 watts, at 32 volts operating voltage I would need to be at about 950mA per transistor to maintain similar dissipation levels, and be content with about 28 watts of total Class A power output.
I hope that this will keep the transistors from going into combustion. 28 watts is sufficient for me.
Old 21st July 2009, 08:52 PM   #4558
pro is offline pro  Italy
pro's Avatar
Last night I tried to make comparative tests between the Zen V4 and F5, using a very well reviewed 5" full range of Italian production. The timbre of the two is slightly different, due to the high output impedance of the V4 (80 hom), but the thing that left me surprised, is that the soundstage of the F5 is at least 15" higher of the Zen one. Could someone try to explain me, the reason for this?
Both ampli with same cable, pre and cd player.
Thank you.
Michele
Old 22nd July 2009, 02:47 AM   #4559
The one and only
A 1 amp bias point will give you 32 watts peak.
2Amp * 2Amp * 8ohms = 32 watts peak = 16 watts rms (average)
Old 22nd July 2009, 02:47 AM   #4560
Formerly "jh6you". R.I.P.
Babowana's Avatar
Steel mills supply mild steel with their mill specs indicating the yield strength of 235 N/sq.mm even if the test results are actually much higher than this value, e.g. 270 N/sq.mm or greater in most cases. Nevertheless, we apply the yielding exactly at 235 N/sq.mm, considering risk management with respect to "life", "property" and "environment" at sea.
The max. gate-drain voltage of 25V given in the datasheet of 2SJ108 reminds me of the similar feeling as above, but no such heavy risk . . .
Sangram, I believe that you would adjust the voltage rating of filter capacitors adequately.
Currently Active Users Viewing This Thread: 5 (4 members and 1 guests)
rothay, hofer, ClothEar
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.19030 seconds (57.58% PHP - 42.42% MySQL) with 11 queries
