| Thread Tools | Search this Thread |
#4531 |
Passive Aggressive
Is that the Dun Mei Audio case from Ebay? Think Dun Mei is how its spelled.
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#4532 |
yes dun mei chassis but i got it directly from china, much cheaper..
even with the current placement of the toroids, i dont hear any hum/hiss coming out of my speakers. very quite. thanks
GB for DC coupled B1 buffer with shunt PSUs WIKI |
#4533 |
You didnt tell what those big tube amps are, but if 845 PP thats some power
#4534 |
oppss... its a diy 805 PP amp..
#4535 |
My F5 is very stable. But I have a problem: when you connect the CD player cable the hum is a very big ... I've tried several cables, but it's just the same ... Without cables, the F5 is very quiet. Can somebody help me with an advice? Thancks! Vitalie |
#4536 | |
Official Court Jester
you probably have ground loop ; if that helps , write again
my Papa is smarter than your Nelson ! tnx to |
#4537 | |
Make sure BOTH are plugged into the SAME outlet. If you can't do that, then use a quality power strip to supply power to both pieces of equipment. Most CD players are NOT grounded, so this may or may not be the problem. Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 |
#4538 |
to keep an account of your advice
#4539 |
Thancks Zen Mod !
Thancks Ron! |
#4540 | |
I have a switchable ground on my amps. If connected to an MP3 player or an ungrounded device then I switch the earth in. If any earthed device causes hum I switch out the earth on the amp.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
| Currently Active Users Viewing This Thread: 4 (3 members and 1 guests) | |
| rothay, hofer |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 2.07913 seconds (9.80% PHP - 90.20% MySQL) with 11 queries |
