#4511 | |
you need high transconductance, medium voltage Vds, lowish noise, jFets of both N and P channel.
Have you downloaded the PASS manual for the F5? |
#4512 |
Yup, and I can't find any of those parts, either 74/370 or 108/170
I poked around here on DIYA trying to get an answer and I dug up this threadToshiba 2sk370 and 2sj108 But it didn't help any. I'm trying to scour the D-K pages looking for alternates. The voltage ratings are easily available but getting the gm and noise figures are proving quite a task. |
#4513 | |
www.amb.org www.ampslab.com and have heard good things about: www.tech-diy.com These are all based in the US though - contact them to see if they will ship to India. Alternately, I'm sure there are places in Europe that stock these parts - the shipping may be a bit more reasonable. -j |
#4514 |
I bought and recieved all my parts in short order from Jackinnj at Tech-Diy.com ....easy to do business with!
Thanks Jack! Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. |
#4515 |
Thanks a lot for the responses, and even to those who emailed me
I was hoping to save on shipping cost by using a single source for all my parts. I notice that Jack has complete partlists for the F5, so maybe that's the ticket. He does mention something about customs, so I'm assuming he ships international. European suppliers may have slightly lower shipping, but the parts seem to be more expensive. I noticed in the 6moons review that Nelson has used 5% Panasonic Metal oxide resistors from D-K. Would there be any downside to just using resistors available locally? The quality of resistors here isn't the best - values may be off tolerance, suspect materials may be used, and resistors may be significantly inductive. But much, much cheaper. Or potentially, an upside to using 'premium' resistors in this design? Thanks again! |
#4516 |
hi
many thanks to all your replies , very helpfull for me. After some test, I have changed the 3 wires ( +, - , GND) between the capacitor of the power supply and the amplifier card to a torsaded computer lan CAT6 wire. like this (one channel only for the test) and this is the result of the trace , more stable than before and this at 20khz and for the fun at 1Mhz ![]() my power supply , CRC 40 000µf+(0,68/4) +100 000µf for each line ![]() I think that I use a fake 9240 (local seller) , I will post the trace on the gate of the 240 and the 9240. I think that the 2940 that I use have too much capacitance between the gate and the source. I'v forget to save it during test. Thanks to all Lalaina |
#4517 |
It's looking pretty good overall.
Is this an atifact of the scope/image or is it HF oscillation. |
#4518 |
And this also.
#4519 |
It's still all very good though
#4520 |
Hi Molly,
I think that it is not an oscillation. this is a digital scope, that is the problem with digital scope |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
