#4491 |
4U may work, depending on air temperature
Heat sink is 300x165x40 My guess is that its Fischer heatsink Sk501 sem to fit the specced size used in modushop box Increasing from 150mm to 200mm height doesnt seem to make significant improvement Its about 0.3K/W in both sizes Curve is almost horisontal at 150mm height, so no further improvement with increased size, it seems But 40mm fins is on the small side and not the most effective SK157 from Fischer has 83mm fins, that seem to be very effective Its close to 0.2K/W at 200mm, and still more to gain, it seems |
#4492 | |
The only problem with the 400 mm unit is that each side/heatsink is devided into two 200 mm pieces mounted side by side. |
#4493 | |
good post ![]() And I obviously only looked at 300mm case
#4494 | |
Michele |
#4495 |
Passive Aggressive
With one side split into two heatsinks you actually get a tiny bit more efficiency out of the heatsinks.
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#4496 |
To get the max efficiency, one should fix the two mosfet exactly at the center of each heatsink. That means about 200 mm apart and at 82 mm high
#4497 |
A question regarding j-fet.
Is it normal that while k170 at 6ma bias, on 30 units, I have found a Vgs which varies between 20 and 80 mV while the J74 varies between -500 and -1500 mV?
Michele |
#4498 |
Did you mean between -500 and -1500 mV or between 50 and 150 mV ? If you meant -500 and -1500, then it is not normal. Firstly I expect your Idss to be larger than 6mA, in which case Vgs should be POSITIVE and not negative for 2SJ74, and vice versa for 2SK170. But suppose that Vgs is positive, and even with the V-grade at 16mA Idss, the Vgs should not be more than +400mV at 6mA bias. Please refer to Page 2 of datasheet. If you indeed measured -1500mV (i.e. the gate voltage is lower than source), you are for certain forward biasing the JFET, and I would have expected a much larger current than 6mA. Or I misunderstood you completely. Patrick |
#4499 |
Hi Patrick. Thank you for the answer.
I arranged this small schematic, and the values I have read between ground and source are from -500 to -1500 with the most, on 30 units, between -800 and -1300 mV. Only one is -60 mV.
Michele |
#4500 |
I can't understand (may be the warm weather) your schematic: gate-drain is 50v? No load? Source resistor = 3870R? Source at 0V ?
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
