#4471 |
you can't measure effective DC offset at full blast ;
if clipping is approx. symmetric , bring your speakers and enjoy .
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#4472 | |
Unbilievable but true! ![]() How is the sound? |
#4473 |
MONO
![]() but sounds no hum, very clear. I have measured about 1hom of output impedence. Bias is 350mA, enough for the FIRST WATT in class A. maybe I'll leave it with this bias, so I can listen in summertime also, withot sweating. I have already the Zen V4 for this
Michele |
#4474 | |
The one and only
#4475 | |
How did you measure that? From PDF: "... Measured Performance The gain of the circuit is 15.15 dB. The input impedance is 101 Kohm, and the output impedance is 0.1 ohms, for a damping factor of 80." ..." |
#4476 |
R21-R22 10K.
Maybe the mains was a little bit low because was 23.3 VDC or the couple not matched of IRFP 140N/9140. Bobo I measured 21.2 V without load, and then 19V with 8 hom load. So 19V/8hom=2.375A. 2.375A/2.1V(the difference beetwen Unloaded and loaded) =1.13 hom. DF=8/1.13=7. Or not Mr Pass, this morning I have read the review of your XP-15 phono stage. One of the best in the world at that price. Ccongratulations.
Michele |
#4477 | |
The voltage difference is mostly due to output devices residual voltage and emittor resistors drop out. So, you dit not evaluate the dynamic output Z ( Z speaker / Damping factor) which takes NFB in account. Though i cannot tell how to measure it... |
#4478 |
reduce your signal so that the output voltage is well below clipping.
Now measure the effect of connecting and disconnecting the load. If it is as bad as 2V then you have built something wrong. A ClassA amplifier should hardly drop at all, due to the continuous loading on the PSU. |
#4479 |
Bobo, the measure is made on a resistor.
This is the dark side of the moon. ![]() Andrew, actually the bias is only 350mV so no class A at clipping, but I will do some measure at lower level, as you say, and i'll report results.
Michele |
#4480 |
Sorry for my wrong last post.
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
