F5 power amplifier
F5 power amplifier
Old 4th July 2009, 04:24 PM   #4391
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
Originally posted by pro
PI isn't a bit overkill is it?
I have made an experiment with 2 x 47000uf only, no resistor ( no pi filter), one channel supplied.
Result:
No hum with 93db efficiency speakers.
Though i have made no measurements.
Ok for me i will go this way
Old 4th July 2009, 04:47 PM   #4392
Renron is offline Renron  United States
Renron's Avatar
HOT DIGGIS
Seems like I asked the right questions this time!
AndrewT, Babowana, Massimo, You guys are Awesome!
Class is in Session!!!
Wonderful explainations, formulas and debates.
I'll probably go with the Pannosonics.
Thank you all,
As far PSUDII goes it workd great for tube PS but does not have the functions required (like a Thermsistor soft start) for this large, power hungry Class A amp.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 4th July 2009, 11:57 PM   #4393
slr 5000 is offline slr 5000  Australia
hi all
heres the pics of the output boards i want to add to the f5 for more power
i realise i will have to change the devices mounted to the baords
and already have enough of the f5 output devices to do this
the f5 will be run the same as the aleph 5 in the pics with 3x n and 3x p devices per amp mounted to the boards via flying leads
when i do this can i crank up the voltage and bias to get more power seeing as im running 6x output devices instead of 2
what sort of power can i expect into 4 ohm and what are ther plus and minus of this approach
regards sheafer
Old 5th July 2009, 12:00 AM   #4394
heres a pic of the aleph 5
this is exactly how the f5 will look using the same output boards run from flying leads off the p daniels f5 boards
Old 5th July 2009, 12:12 AM   #4395
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Originally posted by slr 5000
hi all
regards sheafer
B+ * (b+/ speaker impedance)
If using higher B+ then beware of power dissipation into output transistors and heatsink.
I usually use belt and braces and have a large heatsink plus a couple of fans, one sucking at one corner and the otehr blowing out at the opposite corner.
PCBCAD51 pcb design software. 2018 version out now >>>>>> http://www.murtonpikesystems.co.uk
Old 5th July 2009, 06:40 AM   #4396
And what about the input JFets?
Old 5th July 2009, 09:11 AM   #4397
sorry double post
Old 5th July 2009, 09:11 AM   #4398
i have some if i need to add more
in parralell
do i need to ?
Old 5th July 2009, 12:15 PM   #4399
Default conversion to 3pair output stage
the maximum output power depends totally on the PSU voltage that is available when delivering that maximum power.
The maximum ClassA current depends totally on the bias current you set for the output stage.
The three FETs located near each other will defeat most attempts to dissipate the extra heat expected if you increase the bias by a factor of three and will be exacerbated if you also increase the PSU voltage.
regards Andrew T.
Old 5th July 2009, 01:23 PM   #4400
in parralell
do i need to ?
The input jfets would not appreciate to see more than 24v rails.You'll need to cascode them . Here is an example. (input stage only)
(Buzquito JM Plantefève)
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
