F5 power amplifier
F5 power amplifier
Old 13th June 2009, 06:22 PM   #3991
Originally posted by bobodioulasso
I usually double this rating for a 2x100w class AB amp
Originally posted by AndrewT
1kVA for 100W+100W ClassAB is unusually high. I don't think there are many here who would recommend that VA to W ratio and few builders who would follow that advice.
I do not give any advice, just telling what i do.
For a 2x 100w/8 ohms capable of 2x400w/2 ohms
so which is it that you use?
a 100W+100W amplifier powered by a 1kVA transformer
or
a 200W+200W amplifier powered by a 1kVA transformer
or
a 400W+400W amplifier powered by a 1kVA transformer.
I will answer "advice" by private Email, it's too far off topic to expand here.
regards Andrew T.
Old 13th June 2009, 07:01 PM   #3992
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
F5 power amplifier
Multiply by factor 10, and you are in the clear
But that gets exceedingly difficult with high power amps
Maybe one reason to choose smaller amps
sometimes we know very little, and sometimes we know too much
Old 13th June 2009, 07:44 PM   #3993
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
Just so there is no confusion bias current through each output mosfet is the same as original version.
I was understanding 1,3/3 amps each, sorry...
So your proposal is power hungry.
Old 13th June 2009, 08:43 PM   #3994
Andrew,
Large transformers having a better regulation, the rails are stiffer, giving a tighter response which is a plus , something like an iron fist, never mind calculations.
Just make it big and enjoy!
Old 13th June 2009, 10:05 PM   #3995
Melon Head is offline Melon Head  Australia
Banned
Yes it is power hungry, but it is not extreme.
It certainly is still doable. You would need 500VA transformer per channel.
The the heatsinks would need to be something like this:
MF35-151.5 http://www.conradheatsinks.com/produ..._350.html#MF35
Old 13th June 2009, 11:40 PM   #3996
The the heatsinks would need to be something like this: MF35-151.5 http://www.conradheatsinks.com/prod...0_350.html#MF35
These are just enough for a normal F5. So you'll need three pairs of them here for stereo.
Old 13th June 2009, 11:57 PM   #3997
Banned
There is 30 Watts (heat dissipation) per device, multiply by 6, and you get 180Watts total per channel.
Hence the heat sinks suggested earlier should be adequate.
I know this can be done because I have a JLH class A which dissipates 160W (heat) per channel, and the heat sinks I have are smaller. and I can touch the heatsinks no problem (temp is below 60 degrees Celsius)
Well to be on the safe and conservative side you could buy 4 and make a cube just like the Aleph 3 http://calab.kaist.ac.kr/~cgkim/audi...ages/a3_lg.jpg
Old 14th June 2009, 11:04 AM   #3998
Just make it big
enough.
Yes, I agree.
But you have chosen to not answer the question I asked.
What size of two channel amplifier is your 1kVA transformer driving?
regards Andrew T.
Old 14th June 2009, 02:17 PM   #3999
56oval is offline 56oval  Australia
Hi All
A mate of mine gave me a pair of F5 boards (peter danials design)
I check out diy-tech site and they don't have matched pairs of the jfets ,how important is it to have these matched .
Cheers
Mal
Old 14th June 2009, 02:27 PM   #4000
According to N.P. recommendations, it is not necessary to match them, just use the same group. ( GR, BL...).
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Copyright ©1999-2017 diyAudio
