F5 power amplifier
F5 power amplifier
Old 12th June 2009, 05:55 PM   #3971
udailey is offline udailey  United States
Passive Aggressive
F5 power amplifier
Okay, I saw a guy posting about modding his amp (forget which one, some super commercial brand) by removing some resistors and replacing them with precision current sources. He used LM334 TO-92 packages with current setting resistors in place of a few resistors. Claimed it was great for improving the cymbals sound.
What do you guys think? Hogwash or room for experimentation?
I dont know if this was used in the signal or not, wish I had bookmarked the page.
Uriah
Okay, I found the reference
http://www.drmaudioht.com/BASIC_M1_CurrentSource.htm
Not as I remembered it but its interesting anyway.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 12th June 2009, 06:13 PM   #3972
R-K Rønningstad is offline R-K Rønningstad  Norway
R-K Rønningstad's Avatar
Default F5 + quad
Originally posted by bobodioulasso
Isn't the F5 able to drive loads lower than 8 ohms and so, to reach twice its power?
May be this could explain why Nelson oversized the transformer.
Have anyone of you nice people tried the F5 with the ESL-63 or the original Quad electrostatic?
Old 12th June 2009, 07:20 PM   #3973
Passive Aggressive
F5 power amplifier
In the manual Nelson says:
"In spite of the thermal compensation in the circuit, you should assume that there will be drift as the heat sink temperature
rises, and you will need to readjust the values over the course of an hour or two. Usually it is best to start out bias
adjustment low, at maybe 0.4 mV across R11 and R12 until the amp is warmed up a bit"
Is the drift because P1 and P2 drift in resistance as they warm up from the heat of the heatsink? If not, why?
Uriah
Old 12th June 2009, 07:35 PM   #3974
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 power amplifier
You start around 0.4 V, not mV.
The drift is due to temperature change in the semiconductors.
Old 12th June 2009, 07:40 PM   #3975
Passive Aggressive
F5 power amplifier
Thanks Mr. Pass. And thanks for the clarification on .4V vs .4mV, thats a pretty big difference.
Uriah
Old 13th June 2009, 08:06 AM   #3976
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
Actually, I'm using 500VA transformer for my F5 . . .
I usually double this rating for a 2x100w class AB amp (bottom in multi-amplification). Though, who will use F5 on a 2 ohm load? Is'nt the limiting current circuit set too low for this ( i do not remember, as i do not use any)?
Old 13th June 2009, 08:18 AM   #3977
R.I.P.
"I'm using 500VA transformer for"
1kVA for 100W+100W ClassAB is unusually high. I don't think there are many here who would recommend that VA to W ratio and few builders who would follow that advice.
regards Andrew T.
Old 13th June 2009, 09:22 AM   #3978
It is only sensible to do if you have 100W/8Ohms amps that doubles and doubles each time you divide the load by 2, i.e 200W/4Ohms, 400W/2Ohms and so on.
Old 13th June 2009, 09:25 AM   #3979
I do not give any advice, just telling what i do.
For a 2x 100w/8 ohms capable of 2x400w/2 ohms i do not think i oversize so much the transfo rating. ( See commercial P.A. products)
In the case of the F5/2ohms capable, of coarse , it would be oversized.
As a rule of thumb, when Nelson recommends 600Va, i prefer to follow his instructions rather than to loose myself into uncertain calculations.
Though, Nelson's well known generosity, certainly allow us some margin in our transformer rating choice ( depending on availability and price).
Old 13th June 2009, 09:31 AM   #3980
That's what they call "High current amplifiers".
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
