F5 power amplifier
F5 power amplifier
Old 5th June 2009, 11:26 AM   #3891
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Right! It must 80 not 40!
Then it's better to use normal way...
Best regards,
Ozgur
Old 5th June 2009, 11:27 AM   #3892
R.I.P.
maybe I can't multiply. I thought my mental arithmetic came to 80off.
regards Andrew T.
Old 5th June 2009, 11:29 AM   #3893
Dxvideo's Avatar
No, you were right..
Best regards,
Ozgur
Old 5th June 2009, 12:01 PM   #3894
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
F5 power amplifier
Fore a small AB amp I could do what you suggest, using small caps
Fore classA I would use nothing but big caps, they are tougher
As Andrew explains, too small caps can get pretty hot, if overloaded, and wont last long
sometimes we know very little, and sometimes we know too much
Old 5th June 2009, 12:33 PM   #3895
R.I.P.
I don't agree.
small caps usually have small ripple capacity.
paralleling small caps to equal the capacity of one large cap usually results in more ripple capacity. It thus reduces the risk of overheating and thus increases the life of the capacitors, provided the caps have cool air circulating around them.
regards Andrew T.
Old 5th June 2009, 12:36 PM   #3896
F5 power amplifier
sure
But the question is what is small and what is big
And how many are many
In my book, 22.000uf just starts to get big
And anything below 10.000uf is small
10.000uf I consider neither small nor big
Old 5th June 2009, 12:51 PM   #3897
R.I.P.
small and large don't affect the conclusion you drew.
Many parallel capacitors have a higher ripple capacity than a single capacitor of the same capacity and similar quality. It matters not whether we are looking at pF or nF or uF or mF.
You said
I did not say that.
regards Andrew T.
Old 5th June 2009, 01:16 PM   #3898
F5 power amplifier
Originally posted by AndrewT
I don't agree.
Maybe my english isnt that good
But thats what it meant to me
I may simplify a bit too much
Sorry if I dont understand what you say
Or "quoted" you poorly
btw, do you know "FTcap"
Just saw them on BMM site
Up to 220.000uf in 40V
Old 5th June 2009, 01:26 PM   #3899
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
For each channel i use four 12000uf audio grade Elna (made in Thaïland) which do the job very well. I must say that bias is set at 1 amp.
Old 5th June 2009, 01:28 PM   #3900
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
Hi Ozgur,
To choose the right filter capacitance, we should know what is our DC load current and what should be our target ripple voltage. We are however lucky because Papa has done all these for us in his F5 design.
If you want to apply the same bias current of total 2.6A for both channels, try to keep the CRC filter values of the same as the original. It doesn't matter capacitances are pralleled or not as long as the total capacitance is the same. Meanwhile, if you want to reduce the bias current or increase it, you could change CRC values linearly according to the change-rate of the bias.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
