F5 power amplifier
F5 power amplifier
Old 18th April 2009, 07:58 PM   #3601
bear is offline bear
expert in tautology
bear's Avatar
F5 power amplifier
Stein2,
That looks like an Audiostatic?
I have a friend that runs his Audiostatic panels just fine on a very strong 35w/ch tube amp, and in his room which is likely something on the order of 14 x 14 roughly speaking it is more than loud enough.
If you need more voltage swing, you can bridge a pair. So build the pair you are building now, and if you need 4x the output power, then you can build another pair and bridge them?
Fwiw, I doubt that you will get anything like 98-100db sensitivity from your bass line source. You will get some power handling though. And a bit depends on the wiring scheme as to what you will end up with - if it is a 2 ohm load (for example), then you will gain some apparent output from the amp sinking more current (assuming the amp can do this). Also, I would not count on the manufacturer's SPL rating, they are usually taken at midband, not at LF... measure it urself and see.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 18th April 2009, 08:11 PM   #3602
stein2 is offline stein2  Serbia
stein2's Avatar
Originally posted by bear
Stein2,
Not Audiostatic, made by a local builder who has still a long way to go before he becomes a respected name in international terms, or just might get lucky ... or not...
These run easily if matched up with a Quad405 (but then, 405 was designed for that sort of load) and it remains to be tested when all of the four F5 channels are finished. Then I'll see what's next...
"Calculations? We don't need no stinkin calculations! We just make them really big!" - Papa
Old 18th April 2009, 09:29 PM   #3603
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
Something scratches my head.
Let us have three amps, one big, one medium, one small.
config 1: big for basses, medium for mediums, small for highs. This works say not too bad.
config 2: swap big and small amps (big for highs, small for basses) this does not works. Basses do not accept a small amp.
So what?
Old 18th April 2009, 10:49 PM   #3604
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
Originally posted by bobodioulasso
So what?
I'm with you.
They should have had to bring their consideration of the peak acoustic powers of instruments and voices into their thoughts, too. Each instrument or voice has difference. For example, if we compare peak acoustic power Watts/ sound power level (SPL) dB, it is as follows:
  • Pipe Organ: 12.6 W/ 131dB
  • Bass drum: 10 W/ 130dB
  • Trombone: 6.5 W/ 127dB
  • Singers: 2 W/ 123dB
  • Grand piano: 0.45 W/ 116dB
  • Trumpet: 0.33 W/ 115dB
  • Double bass: 0.16 W/ 112dB
  • Piccolo: 0.08 W/ 109dB
  • Flute: 0.05W/ 107dB
  • Triangle: 0.05W/ 107dB
Old 18th April 2009, 11:05 PM   #3605
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
kwayzee triker ;
these quad405 you heard with these panels were made accordingly to stock schematic , even with eeny weeny ECC83 as substitute for input OP;
there is no 100W/channel even in wildest dreams ....... yup for true 8ohms , but everything bellow 8ohms is just triggering 405's internal current limiting , way bellow 100W
Aleph 5 will make these panels bleed , if you're deaf enough .....
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 19th April 2009, 12:11 AM   #3606
I'm with you.
Thanks Babowana, glad to see i am not alone!
Old 19th April 2009, 04:58 AM   #3607
expert in tautology
bear's Avatar
F5 power amplifier
Originally posted by Babowana
I'm with you.
This is slightly misleading since one usually does not stand in the loft with the pipes, and the organ is played in a very large room where you the listener is a considerable distance away... I also am pretty darn sure that a flute can do more than 107dB (assuming these are 1M measurements?) when played to do that.
Almost no one has a home hi-fi system that can even produce one (1) acoustic watt...
_-_-bear
_-_-bear
Old 19th April 2009, 05:33 AM   #3608
Babowana's Avatar
This is slightly misleading ...
... a flute can do more than 107dB (assuming these are 1M measurements?) ...
Could be . . . Anyhow, the point is why the smaller amp is acceptable for high part in bi-amping.
Yes, watts/sq.M, and dB is re 1 pico-watt/sq.M.
Old 19th April 2009, 11:58 AM   #3609
jackinnj is offline jackinnj  United States
jackinnj's Avatar
F5 power amplifier
_-_-bear
It's power * bandwidth
Guys are getting a tad OT.
Old 19th April 2009, 03:17 PM   #3610
expert in tautology
bear's Avatar
F5 power amplifier
"It"?? It is what?
Perhaps a more complete statement would be in order?
The reason that a smaller amp is acceptable, in many instances, is twofold:
- the tweeter tends to have a higher sensitivity (worth 3-6dB or more)
- If you FFT (for example) a CD track and look at the levels, you'll see that there is less level at HF, so less power might be acceptable.
But, I'd go with the general gist of the earlier comment on having all the drivers capable of similar output levels - or put another way, all capable of exceeding some threshold that is appropriate to the situation. (the same threshold criteria would not apply to a speaker in a 10x10ft or M room as would one that was for a 75x75ft room)
_-_-bear
_-_-bear
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
