F5 power amplifier
F5 power amplifier
Old 9th April 2009, 07:11 AM   #3491
samoloko is offline samoloko  Bulgaria
when start to do F5 initial setting (set the bias and dc out) the input got be connected to the gnd or no
Old 9th April 2009, 10:05 AM   #3492
rob lenk is offline rob lenk  United States
Default f5-test leads
sts9fan
I just tagged them underneath at the solder points and left them long enough to reach beyond the board by an inch or two- I will heat shrink the ends after measurement= little prophylactics!
Again I wish to make it clear that Peter's boards are great- just had to figure out how to fit the Tech-DIY parts and the vertical mount seemed best- Peter's suggestion with the big Dales would certainly make sinking Q1&2/Q5&6 much easier while soldering them in place-
rob
Old 9th April 2009, 10:31 AM   #3493
slr 5000 is offline slr 5000  Australia
hi all
will a bridged f5 still have the same gain as a standard build
or will it be more or less
sheafer
Old 9th April 2009, 12:48 PM   #3494
R.I.P.
a bridged and/or balanced arrangement with the same gain in each half will apply double the output signal voltage across the load.
That is effectively four times the power into the same load or +6dB. Subject to the usual condition that the amp can only supply +6dB if it has a theoretical zero output impedance and it's PSU similarly has a zero output impedance.
regards Andrew T.
Old 9th April 2009, 09:44 PM   #3495
thanks andrew
but just to clarify if the standard f5 is 15db gain will the bridged amp be the same ,eg 15db i know the power output will be more but im confused about the actual gain
regards sheafer
Old 10th April 2009, 05:15 AM   #3496
stein2 is offline stein2  Serbia
stein2's Avatar
Of course, input + and gnd (minus in) should be shorted.
"Calculations? We don't need no stinkin calculations! We just make them really big!" - Papa
Old 10th April 2009, 06:01 AM   #3497
thx for reply
It Is not pointed In manual
Old 10th April 2009, 06:08 AM   #3498
stein2's Avatar
thx for reply
I guess it's one of those "common knowledge" things. To get zero output, one must assure there is zero at the input. Otherwise, if anything appear at the input, the amplifier will produce something at the output...
Old 10th April 2009, 08:08 AM   #3499
cviller is offline cviller  Canada
cviller's Avatar
Actually this description points out a reason why it is a good idea to do the tests without shorting the input - if there is something going on on the output with an open input, you need to fix that problem before connecting speakers.
Remember there is a shunt resistor of 100k on the input, so unless you pick up too much noise, you can assume 0V on the input.
Old 10th April 2009, 08:32 AM   #3500
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
some amps are sensitive to RF garbage , some not - regardless of input impedance ;
that will be step 2 .
step 1 is always with shorted input
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
