F5 power amplifier
F5 power amplifier
Old 16th March 2009, 11:29 AM   #3291
ashaw is offline ashaw  Australia
I have an interest in designing a SMT version of the F5 in the hope that Linear systems comes out with the long awaited LSK74
I was wondering if these two transistors could be substituted for Q5 and Q6 ie ZTX450/ZTX550 and if so what changes would be needed.
FZT792A
FZT692B
Old 16th March 2009, 11:56 AM   #3292
R.I.P.
Hi SLR,
running a bridged pair of F5 into 4r0 is the same as using a pair of single F5 to drive 2r0.
The ClassA power of an F5 is limited by the ClassA bias current.
I begin to wonder why you want to use a rather nice ClassA amplifier to drive bass only speakers, when for much of the time the amps will be running in ClassAB.
Is your decision to use F5 for the bass valid? Or more a view through rose tinted specs?
There are other ways to use your balanced signal to drive your speakers.
regards Andrew T.
Old 16th March 2009, 12:02 PM   #3293
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
Originally posted by ashaw
... what changes would be needed.
You don't need to change anything as long as the NPN substitution has the base-emitter on voltage of about+0.6V while the PNP of about -0.6V.
If the base-emitter on voltages are quite different from the value of 0.6, you need to adjust the size of R19 and R20.
Old 16th March 2009, 12:07 PM   #3294
-0.75 + 0.9.
Old 16th March 2009, 12:09 PM   #3295
R.I.P.
-0.75 + 0.9.
are these the base emitter voltages of the FZT substitutes?
regards Andrew T.
Old 16th March 2009, 12:17 PM   #3296
yes the PNP part FZT792A has a
VBE(on) of -0.75 V at IC=-1A, VCE=-2V
the NPN part FZT692B has a
VBE(on) 0.9 V IC=1A, VCE=2V
Old 16th March 2009, 01:01 PM   #3297
Babowana's Avatar
ashaw,
I could say that both have Vbe(on) of about +0.6 and -0.6V.
Refer to the attached data sheet of FZT692B. So, you could use them as good substitutions without adjustment any.
Old 16th March 2009, 01:07 PM   #3298
cool they are the only smt parts I thought might be similar enough.
I was thinking of making up some test boards to send to someone with these parts, to compare them to the original if anyone would be interested.
Old 16th March 2009, 01:20 PM   #3299
R.I.P.
I have an interest in designing a SMT version of the F5...........
comparisons should be done using as close as possible the range of operating currents expected in the completed amplifiers.
1A @ 2Vce is preposterous.
regards Andrew T.
Old 16th March 2009, 01:26 PM   #3300
yes I do unserstand that, that is why I was asking if I could send some parts to someone better qualified so that they could test them.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
