F5 power amplifier - Page 300 - diyAudio
Old 18th February 2009, 01:44 PM   #2991
rhysh is offline rhysh  United Kingdom
rhysh's Avatar
Send a message via MSN to rhysh
Originally posted by AndrewT
add a bank of 10r 5W resistors together for a soft start ballast.
I use between 30r and 60r for my transformers.
A pair of series 5r0 thermistors will not look like much to a 240Vac supply.
Without a soft start you may need a T8A fuse to start the transformer reliably, i.e. without nuisance blowing every month or two.
Would there be any risks to the amplifiers circuity or transformer by using no soft start, becuase of the large inrush?
R
Old 18th February 2009, 01:54 PM   #2992
RIP
Your caps aren't fully formed yet so they look like a dead short to the trans. Wire up a lightbulb in series as a current limiter and let it cook for a couple hrs then try it.
Best, Bill
Old 18th February 2009, 01:55 PM   #2993
rhysh's Avatar
A standard 60W filament bulb?
Old 18th February 2009, 02:01 PM   #2994
RIP
Anything will work. When you turn it on the light will burn brightly for a second or two, then it will dim. Just let it run like that for a while and your caps will form. If the bulb doesn't dim then there problems somewhere. I start everything I build this way, Poor Man's Variac.
Bill
Old 18th February 2009, 02:03 PM   #2995
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally posted by rhysh
Thermistor is going to be a month! Does anyone have any they could sell to me?
have you any broken PC PSU around ?
you can scavenge NTC that way ......
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 18th February 2009, 02:06 PM   #2996
rhysh's Avatar
I have loads of PC PSU's. Where abouts would i find the thermistor? Near the mains inlet?
Old 18th February 2009, 02:07 PM   #2997
rhysh's Avatar
Bill
Sounds good. Would i still need a 8A fuse whilst doing this, or should i use the standard 1.25A?
Old 18th February 2009, 02:16 PM   #2998
RIP
A 60W bulb will limit the current to about 1/4A so the 1.25 fuse is fine. In the end a 2A slow blow with a CL60 would probably be my choice.
Best, Bill
Old 18th February 2009, 02:18 PM   #2999
rhysh's Avatar
Best, Bill
Thanks, im just creating this contraption now.
Old 18th February 2009, 02:33 PM   #3000
I have just powered up my f5, just the PS. I am using 1.25A fuses on 230v mains. I have tried three times and the fuse blows every time.
Could this be the inrush current of the transformer? The fuse will blow when the transformer alone is connected.
A variac would help in this situation. If you turn the voltage up slowly, and the
variac vibrates unusually, or your fuse blows, you know you have a problem
(hopefully before anything else is destroyed). I got a new 500VA one at Fry's
(in the USA) for about $70 (if I remember correctly).
Good luck,
Robert
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
