F5 power amplifier
F5 power amplifier
Old 12th February 2009, 03:28 PM   #2891
sekess is offline sekess  United States
Thanks Pat,
Steve
Old 12th February 2009, 06:59 PM   #2892
coh-b-pyky is offline coh-b-pyky  Latvia
Default CPU cooler
What about putting CPU coolers (fan-less or with regulated fans) - one per each transistor. Like the one attached. Such coolers with whisper quiet fans (or without) have thermal resistance around 0.15 C/W. That is effectively 100W at 40 DEG C max with room temp. 25 DEG C.
These beasts are much more effective then conventional "audiophile" heat sinks and much cheaper. Available in ANY local computer shop.
Old 12th February 2009, 07:06 PM   #2893
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 power amplifier
I've done that a couple times. The fans still make more noise than
I like, but I did buy a couple Zalman Reserator water coolers.
Old 12th February 2009, 11:30 PM   #2894
labjr is offline labjr  United States
Default Re: CPU cooler
What happens of a fan fails? You know that grinding sound when the bearings in those cheapo fans get loaded with dust. The amplifier goes up in smoke?
What we need is a lesson in making copper heat pipe heat sinks with Freon inside. The ones that look like a Miami Beach high rise condo building.
Old 13th February 2009, 12:17 AM   #2895
WithTarragon is offline WithTarragon  United States
Default Re: Re: CPU cooler
I agree that fans are not reliable. I believe there are designs floating around for a temperature controlled cut-off switch. Would these be a prudent back up plan?
Old 13th February 2009, 01:57 AM   #2896
dcbingaman is offline dcbingaman  United States
Default Conductivity of Urine
Suffice to say it wasn't my idea.....when I was a wee lad I relieved myself on the wrong barred wire fence....I only noticed the insulators after the fact.
BTW, I received (8) 22000 mfd / 35V power supply caps from Digikey today - they are smaller than C-cell batteries !! As I get older, it's like EVERYTHING is getting smaller......
Old 13th February 2009, 03:49 AM   #2897
Aengus is offline Aengus  Canada
Aengus's Avatar
But this may be a consequence of your youthful encounter with the electric fence?
Old 13th February 2009, 10:21 AM   #2898
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
F5 power amplifier
Old 13th February 2009, 01:50 PM   #2899
Could be......but I've still got enough to keep the wife happy !!
Old 13th February 2009, 01:54 PM   #2900
BTW, has anyone tried one of these on a Vandersteen Quatro ? It has a very stable and high input impedance and since the amp only has to drive from ~ 100 hz up, (the woofer is active), I figured that 100 watts would be about right.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
