F5 power amplifier - Page 283 - diyAudio
Old 11th February 2009, 02:19 PM   #2821
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
The On state of a bipolar transistor is defined as 640mV at 10uA and 300K degrees.
But a BJT is not a diode, there's current flowing from the base to emitter at lower Vbe values, also depending on leakage values.
But who gives a hoot about Ib and Ic values in the nano-Amps order, starting at a Vbe of 0.4V and above ?
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 11th February 2009, 02:28 PM   #2822
sekess is offline sekess  United States
Default transformer secondary voltage
I think at least initially I'll go with an unregulated supply and then possibly try a regulated one down the road.
I have a question on the transformer secondary voltage. I had built an unregulated supply for an Aleph J a little while ago. I used 330VA Avel Lindberg transformers with 18 volt secondaries. My line voltage is on the high side at 125V most of the time. I ended up with rail voltages of 22.5 -- a little low.
I was going to try 400VA Antek transformers this time. They have them in both 18v and 20v secondaries. Should I go with 20volt secondaries this time? Or, would that make my rails too high?
Thanks,
Steve
Old 11th February 2009, 02:54 PM   #2823
sekess -
Did you have any type of resistive element in that passive supply, like a resistor or inductor? If so, it would help to have that info from you, and then we could always try using Ohm's Suggestion to figure out the voltage drop. - Pat
Old 11th February 2009, 03:17 PM   #2824
vonfilm is offline vonfilm  United States
Peter,
What parts did you leave out to eliminate current limiting circuitry?
Old 11th February 2009, 03:44 PM   #2825
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
It would look like this: http://www.diyaudio.com/forums/showt...67#post1724767
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 11th February 2009, 03:44 PM   #2826
Default supply
Hey Pat,
I use the recommended unregulated supply. The only difference is that I went dual mono. For each channel, I have a seperate supply. Each supply has it's own transformer, 2 rectifier bridges. The bridges feed CRC (capacitors - resistors - capacitors).
Thanks,
Steve
Old 11th February 2009, 03:53 PM   #2827
Default supply
Each channel's supply has 120,000uF of capacitance and I used .2 ohms for the CRC resistors.
On this supply, the resistance will be a little less - I was planning on using 4 parallel .47ohm resistors (like Nelson uses in his amps) instead of the .2 ohm that I used the last time. But, I think the small difference will be insignificant with respect to the rail voltages.
Old 11th February 2009, 03:55 PM   #2828
pooge is offline pooge  United States
Originally posted by Peter Daniel
I completed my new monoblocks as well, and I'm very happy with the amp; connected directly to a source (no line stage, no attenuator) this is probably the best amp I had in this system.
Disregard AC power connection, it's only temporary.
Nice work. I have been contemplating vertically oriented monoblocks myself. Less floor space, and maybe easier layout of parts inside with respect to connections to PCB, especially if separate input and output supplies are used (in a different amp). I think the top plate may look better rebated into top edge of heat sink, though. Also, you may consider raising the sinks off the footers to get better air flow through the fins, especially over the footers. Don't know about Plitron, but SumR has cans for their transformers with leads that come out on the top. If turned over, they can feed right through the top plate. Have you ever tried SumR toroids? Put some legs on the heat sinks, and a cased transformer, and give R2D2 a woody! Twins!
Old 11th February 2009, 04:51 PM   #2829
My interest for vertical amp chassis was certainly stimulated by that site: http://www.marklevinson.com/image_li...6&productID=12
I've heard about SumR but never used his products. A friend of mine does and seems to be happy.
I could trim the chassis details, but the idea was to build everything in one weekend. Besides, the amps will be sitting behind the wall, so I was not concerned with aesthetics that much.
www.audiosector.com
Old 11th February 2009, 05:04 PM   #2830
Have you ever considered using XLRs instead of RCAs?
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Copyright ©1999-2017 diyAudio
