F5 power amplifier
F5 power amplifier
Old 8th February 2009, 11:56 PM   #2781
raxfor is offline raxfor  Bermuda
hi
dose blanced f5 decrease noise?(like Differential input amp )or it just for more power?
Common Mode Noise dont influe on f5?
Old 9th February 2009, 12:11 AM   #2782
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
F5 power amplifier
Originally posted by JimT
I have the Keystone 4661's and put a IRFP240 on it to check. The two small holes in the mica are low enough down that they are under the plastic part of the case just at its lower edge. The holes should not be an electrical problem.
Jim
Jim, thanks for checking!
Old 9th February 2009, 12:06 PM   #2783
sekess is offline sekess  United States
Default Regulated Supply
Has anyone built up an F5 fed from a regulated supply?
I was wondering if the advantages of a regulated supply would be heard in this case. The noise figure specs seem to be pretty good using a simple symmetric supply. But maybe with regulation the thing would become dead quiet.
Thanks,
Steve
Old 9th February 2009, 12:24 PM   #2784
tubesguy is offline tubesguy  United States
Nelson himself suggested the possibility, and pointed to a couple of regulated supplies in the Zen articles.
I've been pondering the Teddy Pardo Powerreg from pinkfishmedia, but don't know if the pass resistor can really stand up to the large current demands of the F5. Let us know if you give a regulated supply a try.
Old 9th February 2009, 12:31 PM   #2785
Default regulated supply
I'm thinking about it. I'm a little hesitant because of the extra heatsinking for the power supply. It might almost be worth it to put the power supply in it's own seperate case and feed the amp via an umbillical.
The amp itself could be in a smaller case of course.
I have to ponder a bit more.
Steve
Old 9th February 2009, 12:54 PM   #2786
jackinnj is offline jackinnj  United States
jackinnj's Avatar
F5 power amplifier
Default Re: Regulated Supply
Thanks,
Steve
The noise is pretty low -- NP indicated 100uV with 29mF filter caps --
If you use a regulator, the pass devices should be capable of handling 5 amps peak on each side.
Old 9th February 2009, 08:05 PM   #2787
If each device would be capable of 5 amps peak per side and the rule of thumb for a regulated supply is to give it at least 10 times the capacity of what the ampis rated for, then I would need 3 pairs of MOSFETs in the supply -- since the amps output devices are drawing 1.3Amps per device at idle.
Does this sound about right?
If this is correct, that amounts to pretty huge power supply for a 25 watt per channel amplifier.
Steve
Old 9th February 2009, 08:10 PM   #2788
Oh wait,
I think I misunderstood what you said. Your saying that the capacity of the supply MOSFETs should be 5 amps for the F5 -- in that case, I'd be ok with one pair of IRFP's per power supply per channel.
Steve
Old 9th February 2009, 08:32 PM   #2789
amp_guy is offline amp_guy  United States
Of course dissapation can be fairly low in regulators , depending on what voltage your raw supply is at . You may not need that much sinking. Are you thinking tight regulation or mostly capacitance multiplication?
Old 9th February 2009, 08:38 PM   #2790
I was thinking capacitance multiplication. But, I have not decided yet. I was trying to get a feel for what a regulated supply build would entail and if the extra effort would yield a significant enough improvement in the sound.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
