F5 power amplifier
F5 power amplifier
Old 7th February 2009, 03:01 PM   #2751
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
F5 power amplifier
Default Which caps?
Originally posted by samsagaz
wich caps you guys recommend me for Power Supply?
I'm using 15000uF 35V P6668-ND CAPACITOR 15000UF 35V ELECT TSHA from DigiKey, but read posts Post #2581 through Post #2597 .
Nelsons F5 owners manual suggests minimum 15000uF each of eight caps and I would not go lower than 35 volts.
Old 7th February 2009, 03:21 PM   #2752
Ed LaFontaine is offline Ed LaFontaine  United States
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
After posting my choice for caps in #2589, I became aware of problems that others here have experienced with that seller.
Buyer beware.
I had no problems as others did. Mine was a satisfactory transaction. I hope the same for all.
Old 7th February 2009, 05:06 PM   #2753
samsagaz is offline samsagaz  Argentina
Default Re: Which caps?
Ok, will purchase some Panasonics and will go safe
Old 7th February 2009, 05:09 PM   #2754
bubba177 is offline bubba177  United States
I could use some input from y'all on this one--could the output of a F5 be feed into the input of an F4 so the F4 could drive a woofer through it's crossover and the F5 could drive a lowther trough it's crossover as in the F4 manual for using flea amps????
Old 7th February 2009, 08:26 PM   #2755
woodturner-fran is offline woodturner-fran  Ireland
Woo Hoo!!!
OK I have it sorted! thing is I don't really know exactly what was at fault, but prob a combination of things.
What I did was take out the board, remove the pots and Q1/2 and i cleaned all the board down removing any solder etc from where Q1/2 etc had been. I washed all the flux off the board and to be honest I couldnt see anything wrong. So I refitted the parts and reflowed all my solder joints.
I also cleaned down the heatsink and Q3/4 with alcohol and scavenged some thermal pads from a dead switch mode PS.
Fired it back up and it works. Seems very stable, bias does climb slowly and rises with temperature, but it has been playing now for about 4 hours and all is well. I let it run for 2 hours into a 6R8 power resistor to test out first.
I'm not 100% happy at leaving out the thermal compensation, as the bias does rise and fall a bit with internal temp. Perhaps someone who knows could comment on what kind of variation in bias it is normal (or at least ok) to see in use in real life, ie music playing into a speaker.
I have another question too:
I would like to get some thermal pads from mouser. Can anyone give me part number for them... I've searched and not found (for Q3/4).
Temp readings to follow later.... but safe to say all seems to be ok.
Fran
Old 7th February 2009, 08:49 PM   #2756
ichiban's Avatar
F5 power amplifier
Fran
Mouser Kapton 175-6-280p <----I saw these
I will use these from digikey
BER120-ND HEATPAD TO-247 .006" K10 1.360each
Old 7th February 2009, 08:52 PM   #2757
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
yup ;
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 7th February 2009, 08:55 PM   #2758
tms0425 is offline tms0425  United States
I've used the Bergquist BER120-ND from Digikey on F4 and F5 with great results.
Old 7th February 2009, 09:56 PM   #2759
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
Woo Hoo!!!
Congratulations! Wnjoy! Be Happy!
Old 7th February 2009, 10:01 PM   #2760
what about BER131-ND? are cheap
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2017 diyAudio
