F5 power amplifier
F5 power amplifier
Old 6th February 2009, 02:13 PM   #2721
woodturner-fran is offline woodturner-fran  Ireland
Well,
the amp sitting on the bench with no source or speakers is 100% stable. Haven't tried it with source but not connected to speakers. Will try that tonight too, although it won't be long till I run out of source resistors.
Gonna order more parts from mouser tonight.
more later.....
Fran
Old 6th February 2009, 03:06 PM   #2722
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
F5 power amplifier
Originally posted by woodturner-fran
Well,
more later.....
Fran
Hmm, based on my limited under standing of the physical world, I think when driving a speaker, a higher amount of heat in AB may be generated to the amp. In my business, faulty connections fail when more stuff passes through it. So I assume that the speaker presents a different situation to the amp than running with no load.
I would think something as simple as a bad solder joint could be at play, or some other resistor failing causing a higher load to the amp. It works until limits are pushed.
Old 6th February 2009, 03:08 PM   #2723
two further tests before you risk connecting your speakers.
test 1.) connect a music source and play quiet music with the output still open circuit. How long does it play before blowing the resistors?
test 2.) connect an 8r0 load to the speaker terminals. connect a source and play quiet music into the resistor load. How long till the resistors fail?
During your tests over several hours I suggest you measure the output offset and check the average AC voltage at the output (~0.5Vac to 2Vac).
regards Andrew T.
Old 6th February 2009, 04:04 PM   #2724
bubba177 is offline bubba177  United States
fran-i had trouble with the pads and went with mica and grease--it's cheap and works--just my 2 cents-mark
Old 6th February 2009, 04:05 PM   #2725
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
F5 power amplifier
Default Oscillations
Originally posted by cviller
I bet you are more likely to get oscillations if you place the gatestoppers dangling... and if you do get oscillations in this amp, it would most likely be due to incorrect wiring.
CViller, thank you again for providing us diyers these nice boards.
I'm not sure what you mean by dangling, perhaps because the resistor lead goes past the end of the board and is bent around it?
That is just temporary to keep it from flopping around. When the mosFets are in place and soldered on, the resistor lead will be soldered right at the mosFet giving only a couple of millimeters of lead.
I've read the suggestion in another thread on mosfet amps oscillating,
that splitting the resistance in half and putting one at the driver transistor on the board and the other at the mosfet. This was the suggested by a person that worked for a living designing (if I remember correctly) rf-equipement. That would be required when there is a wire from the pcb to a mounted mosfet.
Originally posted by Zen Mod
@ Fran - have you possibility to look at output ( with setup as is - cables , source) with CRO ?seems that you have oscillations , and not having current limiter parts doesn't help you with this ......
...just my --From the Pass F5 Service Manual...............
A caveat is in order here Ė this is a very wide band amplifier with a high input impedance. In order to prevent the output
voltage from bleeding back to the input at very high frequencies (thus making a fi ne power oscillator), keep the input and
output cables separate, and donít externally connect the speaker ground to the input ground. Good ground shielding on the
input cables is important, and caution is called for in using Litz and other specially low inductance / high capacitance cables.
I have not seen a specifi c example of a problem, but historically it is to be expected when an amplifi erís bandwidth exceeds
200 KHz. If the amp makes funny noises, runs extra hot, or blows fuses, this might be an indicator of such an issue.
Old 6th February 2009, 05:42 PM   #2726
Hi all,
First to answer a few of the questions/comments:
1. Cviller: Gate stoppers are right on the gates short resistor leads just 2mm above the wide part of the mosfets leg.
2. Ichiban: ICs and speaker cables are kept well separated. Internally in the amp speaker grounds, PS ground are brought together at the speaker terminals. Input grounds go to the boards. circuit ground tied to chassis earth through back to back diodes paralleled with 0.01uF cap and 15R resistor. Summary: i think I have wired the amp correctly... but am open to correction!
3. AndrewT: partially answering your Q - I have monitored DC offset and it stays low throughout until the resistors go. Bias is a bit jumpy as music plays, might flick up and down by maybe 30mV, really quickly. Settles within a second or 2 of no music playing.
So jobs to do tonight:
1. Babowana: I will measure Vgs of the jfets
2. Fit new resistors and get the amp running again.
3. ZenmodLook at output on CRO, although I'm not sure what exactly to look for!
4. AndrewT Test for time amp is viable with no speaker connected and with resistor in place.
Lastly, I am very tempted to fit the fairchild mosfets and see if that sorts out this issue, although I would like to find out whats wrong.
If anyone has any other ideas, feel free to post them up here. I will also take some pics tonight and post them
Thank you all for your help and support!
Fran
Old 6th February 2009, 05:51 PM   #2727
Tea-Bag's Avatar
F5 power amplifier
Default Re: Oscillations
A question on this then,
For the F4, I grounded the signal input ground and speaker output together on my jumper between the power supply output end.
For this amp, I should do otherwise?
Right now, with F5 -with my little FR speakers, with the signal, speaker and chassis ground all together in a clip lead composite, I have no problems. Nelson mentions externally grounded....So I don't think there is a problem if the grounds are stared together in the amp.
Am I wrong?
Tea-Bag.
Old 6th February 2009, 05:58 PM   #2728
cviller is offline cviller  Canada
cviller's Avatar
That's good, but I seriously doubt you'll get any benefit from mounting the gatestoppers like this. With normal placement you only have a centimeter or so to the resistor, which only becomes interesting way up in the MHz range. Good cabling on the input/output is more important with this amp.
Old 6th February 2009, 07:58 PM   #2729
Babowana Vgs of Q1 (sk170) is 20.86V with R11/12 blown and trimmers left as they were. Vgs of Q2 2SJ74 is 20.68V
I fitted new R11 and R12 and one thing I did do thats maybe just a stab in the dark....
in my setup the mosfets are on short leads (30mm) with the stopper right on the pin. But I also populated the stopper on the PCB too, but had shorted it with some wire. So i cut that wire, so effectively now I have 2 x 47R in series for stoppers, one on the PCB and one on the gate.
So far amp is warming up but bias is behaving normally so far.
More later....
Fran
Old 6th February 2009, 08:18 PM   #2730
ichiban's Avatar
F5 power amplifier
Woodturner-fran
Sounds like you have the wiring sorted out very well.
I was just throwing out a hint mainly reguarding the
possible cable inductances/capacitances. I'm not sure
about the electrostats.
Tea-Bag
I'll have to bow to those more knowledgeable on the grounding.
CViller
"With normal placement you only have a centimeter or so to the resistor, which only becomes interesting way up in the MHz range."
Just being careful. When I built the Borbely mosfet amps I recall warnings of oscillations in the
MHz range. Audio Amature had a number of fixes for that. It wasn,t until recently that I read
about using the stoppers at the drivers and outputs to mitigate the chance of oscillations due to
the inches of wire from board to output mosfets (inductance is the enemy).
Yes, the F5 boards make for a very compact layout helping enormously.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
