F5 power amplifier
F5 power amplifier
Old 5th February 2009, 01:38 AM   #2691
EUVL is offline EUVL  Europe
> you can try with them , but these have fairly low xconductance comparing to verticals ;and you need gain in F5 output stage ...... you'll have lower open loop gain , so less feedback ;
True. But you can lower the source resistor from 0R47 to 0R22 to compensate for that, as the source resistor is actually dominating in the original circuit.
> second - they also have pretty smaller Ugs , so drain resistors in first stage must be smaller , further decreasing that stage gain ...... further decreasing OLG
Not true. You can keep the drain resistor values by lowering the first stage bias by say 2mA or so. No problems for the JFETs.
> don't think that you're first with these thoughts
Of course not. Been there before, umteen pages back.
Jackinnj also have a layout with Hitachi laterals.
Patrick
Old 5th February 2009, 01:49 AM   #2692
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
Patrick
true ...... but even in stock F5 current through first (Jfet) stage is already on lowish side ........
I know that Jackinnj tried them ( and like them ) ...... but 2mA is sooo low ..... and that wasn't F5 anymore ;
you can do that , Jack too ..... but not everyone , knowing what's needed to make it work .
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th February 2009, 01:59 AM   #2693
I said, "You can keep the drain resistor values by lowering the first stage bias by say 2mA or so."
8mA - 2mA = 6mA, not 2mA, Sir.
Patrick
Old 5th February 2009, 02:01 AM   #2694
Zen Mod's Avatar
F5 power amplifier
Patrick
thank you , Sir .
Old 5th February 2009, 02:05 AM   #2695
You're welcome.
Patrick
Old 5th February 2009, 02:32 AM   #2696
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
F5 power amplifier Send a message via AIM to Peter Daniel
Any particular reason that feedback resistors are listed as 3W, they seem to run rather cool?
To order kits contact me through forum mail.
Old 5th February 2009, 02:36 AM   #2697
The theoretical max swing is say -4V from rail.
Even in my balanced version, that would be 12V. Which means 10V across the feedback resistor.
10*10/50/2 = 1W. Safety factor 3 -> 3W.
I actually use 4x PRP 1W in parallel.
Actual signal level is of course normally much lower.
So in theory you might get away with 0.5W or so.
Patrick
Old 5th February 2009, 03:01 AM   #2698
jackinnj is offline jackinnj  United States
jackinnj's Avatar
F5 power amplifier
Oh man, I am in trouble now.
I am using 4 F5's -- with Fairchild devices driving these Pioneer (TAD) S-1eX spxrs. I have a bunch of the Renesas (Hitachi) devices but haven't used them since last year.
On the bench is an NP/aX design from the AX article -- and we are are gonna look at the THD% figures for various combinations of JFET with Idss all over the lot. I know that THD% is not the ne plus ultra stat for the definition of quality, but it's the onlu completely reliable and reproducible stat that I can produce.
Old 5th February 2009, 02:27 PM   #2699
woodturner-fran is offline woodturner-fran  Ireland
Something odd is going on with my F5. When I push the volume a bit I get lots of breakup distortion.
Need to investigate this.....
Fran
Old 5th February 2009, 03:17 PM   #2700
udailey is offline udailey  United States
Passive Aggressive
F5 power amplifier
Fran,
Try a new pot and also reflow your solder connections to the pot on the board and on the pot. If that doesnt do it then try reflowing the rest of your soldering. I find that usually when I have crackling due to change in volume that there is a screwed up solder joint somewhere and I have also had that happen with junk pots or nice pots with bad solder joints. Never know, if you are using a stepped pot you could have a nasty joint somewhere on there as well.
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
