#2681 |
The one and only
There's a reason why the thermistors are there. You don't have to
have them, but you'll spend a lot more time warming it up since the bias starts out low.
#2682 | |
don't tell me that I didn't told ya ......
my Papa is smarter than your Nelson ! tnx to |
#2683 | |
As the temp goes up, the resistors only drift slightly in resistance, but when they reach their rated temp, their power handling drops (again, check the data sheets for temperature drift and power derating - I'm sure 3W is fine). As far as I know (someone correct me if I'm wrong), the resistor returns to normal when it's cooled. What you'll have to do is go through the biasing procedure again, but with the case on... if you have MM leads with clips on the ends running through vent holes in the case, this might work. Or yeah, just replace the thermistors. -j |
#2684 | |
#2685 | |||
******************************* As it stands right now, I'm running the IR mosfets and form teh above you know the set up. Now, I have a second set of boards, I have more SJ74/SK170 coming from jackiinj and I have a set of fairchild mosfets I got form mouser. I'm strongly thinking of buying the few parts needed to populate the second set of boards the same way and after appropriate listening time swap in the fairchilds and see the difference. I haven't read all of this thread (about 15 pages in from each end), but I Nelson would say the fairchilds measure better, but the IRs are a little "warmer". Now from what I heard last night the IRs aren't lacking top end, they have a lovely unforced airiness that you hear from really good valve amps. Would it be a worthwhile experiment? Has anyone in the pages I haven't read done it? Fran |
#2686 |
The one and only
The "warmth" of the IR's is due to the transconductance shelf in
the IR P channel devices. They have higher transconductance at low frequencies, and then go through what looks like "baffle step correction" going into the midrange. If you like it, it's probably because you like less feedback on the top and more control on the bottom. Or not.
#2687 |
Thats interesting. My speakers are quad 57s and as I understand it, they present a widely varying load - with the higher freqs demanding more current, opposite to the norm. I wonder if thats anything to do with it.
In any case, I need to "prove" this amp for a while, make sure its stable, live with it and get to know the sound before making any changes. I have a friend with some very nice marten design speakers that would give it a good run. I ran the mini-aleph there for a while so I kinda have a handle on "if it sounds like this with the quads it'll sound like that with the martens"...... that will be an interesting listen too. Fran |
#2688 | |
space charged
which IRs are you using, I have sets from a Borbely B60 and D100. 2SJ50/2SK135s and the others are higher power versions, I forget the numbers 2SJ56 & ??, all TO3s tho. Your comment about them being warm but with airiness sounds interesting. I know these mosfets were designed for audio use and are fairly complementary!?
#2689 |
The IR ones I'm using are from jackinnj (ie tech-diy.com) and are the standard IRFP240/IRFP9240. The fairchild ones are the 19P20 and whatever the N-channel version is called (from mouser).
I left the amp run for a good 3 hours tonight and it seemed to play flawlessly for that time. I set the bias a little lower while on the open table, about 0.57 or so. Here the heatsinks ran to ~45 degC. Moved into the rack and the heatsinks got a little warmer, taking numerous measurements over the whole area of the heatsinks, I get a range of temps from 45-50 deg C. So that would seem to be in the correct kind of area to be hitting (room temp 21-22 degC). Another few successful cycles like that and I'll be a happy camper. *********************** Definitely this is a better sounding amp than the mini-aleph (which is in itself a fine sounding amp). And where it seems to do best is from mids on upwards. Now bear in mind I listening thru quads so I don't have access to subterranean bass. Anyway, mids and highs are definitely improved. There seems to be a good resolution there and the soundstage is very good. I think this amp has hit a real sweet spot in that it gives a neutral sound, but still seems to have a sweetness higher up - so you don't seem to get any harshness - but yet is not too lean. I'm looking forward to it settling down and me getting to know it a bit better. Hats off to you Nelson for this amp. You should be rightly proud. ************************ Fran
#2690 | |
you can try with them , but these have fairly low xconductance comparing to verticals ;and you need gain in F5 output stage ...... you'll have lower open loop gain , so less feedback ; without any calculation - that amp should have smaller damping factor than F5 ....... second - they also have pretty smaller Ugs , so drain resistors in first stage must be smaller , further decreasing that stage gain ...... further decreasing OLG don't think that you're first with these thoughts
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
