#2661 | |
- Fred - |
#2662 |
hi everybody ! i found new transistors for f5.. they are irfp150n and fairchild's sfh9154 .. they have more input capacitance but sounds very well.they are like complementary transistors.they have same gate voltage..bass and treble are also good
#2663 | |
Rich |
#2664 |
Hi Cviller,
I want to order the F5 boards, but am a new member so cannot mail you directly. Can you mail me to initiate? Or what are the alternatives? Trishend |
#2665 | |
space charged
I've yet to find a way to setup two F5s in balanced mode, and I'm hoping the Conrad MF35-151.5's will handle the heat. The remaining parts from Digikey arrive Thursday, so maybe by this weekend I'll hear what everyone has been talking about.
#2666 |
Nice looking box there ichiban.
Tonight I made more progress... but first a step back. I took and then labelled a pic of what I did with the output resistors. Seems that its part of my penance to show it all but maybe it might save some other poor soul. Morgan Jones talks in his book about never working when you're tired or late at night... well its then or never around these here parts! The boards are messy, bits having been soldered in and out a good few times so excuse the looks ok?! So look, if it saves anyone else... ![]() and here she is powered up in the workshop, front face on, lid in place. I ended up painting it a nice shade of metallic green. I have it inside now playing a disc but am about to head downstairs and have a listen before bedtime. thanks again to Nelson, Peter and all who helped out here. everyone. ![]() Fran |
#2667 | |
I wish I had some of those nice milled and drilled Conrads. Very nice I'm not really sure you'll have enough dissapation to put 4 channels of those 2 sinks. If I recall it's 62w each, so might be tough with 4. Also, that layout of toroids will get one of them VERY close to the signal wires on the back panel. If you want to try it I would mock it up with the supply on the bench, handwired to 2 boards first, then try a 4 if all goes well. Instead of tapping the heatsinks for all of them right away, I would be inclined to use flat bar stock temporarily clamped over the pairs of Mosfets. If it won't work that way in free air, the closed case with toroids inside definitely wouldn't make it. With all that said, my pair does not run as hot as I though it would. The F4's run about 45 C biased up a little harder than Nelson recommended. |
#2668 | |
The one and only
#2669 | |
#2670 |
not politcally affiliated
I was playing with the F5 and wondered why the V+ and - was around 22.5v Then I looked at my parts. For R5-R8, I used INDUCTIVE wirewounds. I think this may be the reason. (This was purely a lack of looking at the obvious when ordering) Is this a big problem? Tea-Bag
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
