F5 power amplifier - Page 262 - diyAudio
Old 31st January 2009, 05:55 PM   #2611
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
dcb,
i already gathered that from your 50w post, mine was a addition to the question of the "smacking" Tea-Bag.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 31st January 2009, 06:09 PM   #2612
Default Bridged F5's
Jacco - cool. I think the last thing one wants to mess with is Papa's choice of the bias point on his selected MOSFETs.....my guess is Pass does a LOT of testing and listening to determine this, and I don't presume to think I can do any better.
I do think a "double-bridged" F5 would be a pretty cool project and would make one hell of an amplifier. In fact, given the simplicity of the circuit, ease of building these things and the high input impedance of the JFET's Pass has chosen, I suspect "scale-up" was an implicit design objective.
Old 31st January 2009, 11:39 PM   #2613
Originally posted by Zen Mod
if nothing else - go to Papa's site ( Pass Diy ) and download few pdfs ...
I mean that in "discrete OP for DIY " ( or something like that ) file you can find how to test jfets and mosfets .
use your imagination , and learn something ......
Thanks Zen Mod.
I'll build the jfet testing circuit and see what comes of it. I just thought someone might know right away if putting Q2 in backwards would fry it or not. Anyway.... I've ordered some more Q1 and Q2.
If Q1/2 check out ok on the test circuit I suppose the next step is to look at the current limiting parts. Test TH1/2. I'm a little concerned that I've actually used NTE128/129 instead of the ZTX450/550 (which is what mouser threw up for ZTX450/550 part). So that might also be the problem.
Thanks for the help.. will hope to do some testing tomorrow and will report back here with the results.
Fran
Old 31st January 2009, 11:44 PM   #2614
tms0425 is offline tms0425  United States
You can probably just take those current limiting parts out, replace the thermistors with 4.7k or so and see what happens. At least to eliminate those as sources of problem. After that, there aren't many parts left to go wrong Tom
Old 31st January 2009, 11:48 PM   #2615
Thanks Tom,
I know what you mean about the parts - thats why I was so p***ed off when I saw what I'd done!
Anyway, more investigations tomorrow. For tonight, its me and some Aretha, Otis and Carla Thomas. Chill out time!
Fran
Old 1st February 2009, 01:07 AM   #2616
I was tapping and drilling on my F5 chassis tonight after a long day and decided it was time to just kick back and relax... lest I make a(nother) mistake One more heatsink to go and hopefully fire it up with no smoke. The power supply with Christian's board and the AnTek toroid works just fine so far at +/-25 unloaded.
Just remember stuff happens to all of us. Hang in there. It should be easy to fix and it will be worth it!
Old 1st February 2009, 02:10 AM   #2617
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
If you check that link, you might think that it shouldn't: http://www.diyaudio.com/forums/showt...52#post1202052
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 1st February 2009, 09:34 AM   #2618
Thanks Peter,
some testing to follow today. To be honest I'm kinda hoping that it is the problem! Otherwise theres another issue....
Fran
Old 1st February 2009, 10:57 AM   #2619
umut1001's Avatar
hi..what is the input voltage to get 25watt class a and 50watts class ab? thanks
Old 1st February 2009, 02:19 PM   #2620
OK, so I done some more testing. First up was to check out Q1/Q2. I made up the circuit that someone posted a little back up here (Idss) - and I got 10mA for SJ74 and 9mA for SK170. So it would seem that they were alive still.
Next I decided to look at the current limiting circuit. I removed all the components from the circuit as detailed earlier in the thread. Now I found I could get the bias set ok across R11 and 12. Its set as 0.6V on both but my offset at the speaker terminals is high. The mosfets are heating up nicely, but they aren't that hot. I've left it on for a little while and will go back and check it again. The offset I'm seeing is "floating" ie moving around a good bit while the bias values seem pretty stable. I get 4.4-4.6V G-S on Q3 and 4 and I meaure 16V D to S on Q1 and 2.
Does this sound OK?
Fran
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2017 diyAudio
