F5 power amplifier
F5 power amplifier
Old 31st January 2009, 03:31 PM   #2601
umut1001 is offline umut1001  Europe
umut1001's Avatar
thank you EUVL ! how can we redesign with different transistors ? nelson says simulations are not good enough..
Old 31st January 2009, 03:31 PM   #2602
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
Originally posted by Diomedian
The following paragraphs are a question, rather than a statement. :-)
When using the Fairchild parts, the transconductance of the the P-channel parts is higher - so in the upper half of the circuit, you've got a lower S jfet and a higher S mosfet, and the lower half of the circuit you get a higher S jfet feeding a lower S mosfet, and these two combinations (partially?) cancel each other out.
Now when you're using the Toshiba mosfets, based on the fact that they're so well matched for transconductance, and that the jfets still aren't, you need to reduce the current output of the P-channel jfet (2sj74) and this is why you've increased source and feedback resistors.
Is this in the right ball park?
Thanks for the tips Patrick - I may end up going Fairchild unless I manage a bit better understanding here.
-j
you must look at amp as whole ....
besides xconductance , N and P type mozfets have different Ugs ;
that means that - chasing needed current and offset in/on output of amp - two pots will have different settings ............ so input Jfets will have different gains .
solution is simple .... ask Papa which THD gadget he's using ...... and what's good value of this horny resistor , for start
edit : writing about different xconductance - I have strictly IRFs on mind
Toshiba's are different animals
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 31st January 2009, 03:34 PM   #2603
EUVL is offline EUVL  Europe
> Now when you're using the Toshiba mosfets, based on the fact that they're so well matched for transconductance, and that the jfets still aren't, .....
you need to reduce the effective transconductance of the P JFET by using a slightly larger source resistor. Once you have done that, of course you need to increase the feedback resistor as well to maintain the same closed loop gain.
At least that is my understanding.
I think I'll leave this question to the Master himself, if I may .....
Not the case for Toshiba's. They have essentially the same Vgs for a particular current. That is the beauty, especially if you want to reduce the source resistor of the MOSFETs.
Patrick
Old 31st January 2009, 03:36 PM   #2604
umut1001's Avatar
Originally posted by EUVL
> but these mosfets are expensive..can we try irf540 /9540 ?they are much cheaper...but maybe the circuit must be redesigned
Maybe you should just stick to the Fairchilds and the original Pass circuit.
You would not get the best from the Toshiba's unless you change the circuit to balance the open loop gain of the top half to the bottom half.
As to FETs being expensive, I wonder what % they cost compared to your finished amp with proper housings, heatsinks, power supplies, connectors, .......
Patrick
> you say you should change other things..can you show us redesigned f5 amp for 2sk1530/j201 ?
I can tell you off what I am using for my balanced version, but no guarantee for single ended :
Rail +/- 16V, 2A bias per MosFET
Source resistor 0R22
Gate resistor 100R
No thermistors, no current limiter (build at own risk !!!!)
Choose JFETs with Idss around 6.5mA.
For the 2SJ74 ONLY, change source resistor from 10R to 13R, and feedback resistor from 50R to 65R.
Patrick
Disclaimer :
Build at your own risk !!
thanks EUVL .. how can we redesign our amplifiers with different output transistors? Nelson said simulators are not good enough..
Old 31st January 2009, 03:40 PM   #2605
Zen Mod's Avatar
F5 power amplifier
Patrick
sorry - off course that I meant strictly on IRFs , but I forgot to write that .
Old 31st January 2009, 03:44 PM   #2606
Even worst for Fairchilds. And the transconductances differ by miles. You just need to roll back umteen pages for the measured data I published here. This is why the source resistor has to be such high value.
Of course one can compensate for all these things by clever design. I am just too lazy and rather use better matched (complementary) devices.
If only the JFETs would be just as good .....
Patrick
Old 31st January 2009, 03:47 PM   #2607
Zen Mod's Avatar
F5 power amplifier
Of course one can compensate for all these things by clever design. .....
Patrick
that's easy ...... and well known - 100db of NFB
Old 31st January 2009, 04:16 PM   #2608
I thought you're a loyal Pass fan ??
Patrick
Old 31st January 2009, 04:35 PM   #2609
Zen Mod's Avatar
F5 power amplifier
Patrick
I'm too flippant to be anyone's loyal fan.....
(rispetto is totally another thing , btw . )
Old 31st January 2009, 05:41 PM   #2610
dcbingaman is offline dcbingaman  United States
Default Bridged F5's
Each side of a bridged F5 pair biased at 2.5A means an idle dissipation of 57W for each output device (24V rails minus the voltage drop across 0.47 Ohm, times 2.5A)
You'll slow-fry both the output devices AND the 0.47 Ohm/3W resistors (0.47*2.5*2.5= ~3W )
Only way to safely up the bias on a bridged F5 is more output devices in parallel.
Easiest is just placing two F5's in parallel, the joy of the steep input impedance of JFETs and the ease with which they allow to be put in parallel. (in particular with degeneration)
200W in 4 Ohm is +7 Amps output current, just the drop of 3.3V across a 0.47 Ohm resistor will make the spec impossible to reach by bridging just a single pair of F5's. (same story with the 120W/8 talk)
Jacco, you are no doubt correct - but I wasn't talking about altering the bias at all. The amp will easily put 2.5A into a 4 ohm load, unbridged, and 2.5A into an 8 ohm load bridged, but probably not in Class A and not steady state with music signals. Putting two F5s in parallel on each side of the bridge doubles the bias and will increase the Class A output point, but also doubles the part count, heat dissipation, yada-yada-yada. It would also probably give you an amp comparable to a DIY Pass X160. Maybe I need to order another four boards from Peter Daniel......
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
