Old 22nd April 2008, 08:57 PM   #251
The one and only
Nelson Pass's Avatar
If you use 2 of them per channel.
Old 22nd April 2008, 09:17 PM   #252
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
heatsink rule of thumb... take what you think is good enough, then double it.
or use fans.
Old 22nd April 2008, 09:29 PM   #253
KSTR is offline KSTR  Germany
KSTR's Avatar
Originally posted by EUVL
I have not managed to figure out why you [TimS in his last proposal] need diodes between the JFET gates ??
To get the front end bias back up while keeping the 100R's in the sources, it looks like. Probably not the most elegant solution (wrt impedance, PSRR).
- Klaus
Old 22nd April 2008, 09:38 PM   #254
So I'd be better off just getting 2 12" long ones? They do .375 c/w. With just 2 fets be hard to put them on 2 different heatsinks I would think. Unless I didn't mount them on the PCB but wouldn't that take away from the sound quality? I've heard some people say they should be on as short of leads as possible.
Old 22nd April 2008, 10:08 PM   #255
Thumbs up Woohoo!
My copy of AX has arrived!
Thank you so much, Mr. Pass. (And I wish you
a speedy recovery.)
Dennis
Old 22nd April 2008, 11:03 PM   #256
The one and only
No problem. I would just run a few inches of wire either way.
Old 22nd April 2008, 11:06 PM   #257
Ok well I have 6 of those 6" heatsinks so I could use 2 per monoblock. I'm trying to figure out the easiest way for me to make some PCB's. I found a place that will let you do 3 small boards for like 51 bucks + shipping. Anyone know a better deal? I saw the printer mod for the epson and it looks nice but I think I'd spend more then 51 bucks on that and not sure I'd use it often enough to have a dedicated printer for printing PCB's. Also saw the iron on method with a laser printer but again I'd have to buy a laser printer.
Old 22nd April 2008, 11:29 PM   #258
The one and only
If you toss the current limiting and temp compensation, there's barely
enough to justify a board. Get some prototype board at Radio Shack.
Old 22nd April 2008, 11:30 PM   #259
Ok I could probably do that. Is there going to be a version for balanced inputs?
Old 23rd April 2008, 12:30 AM   #260
defect9 is offline defect9  Ireland
defect9's Avatar
Default Re: F5 Pcb
Originally posted by apassgear
Here is one way we could lay a one sided board for the F5 circuit based directly on Nelson’s schematic.
Still on the proofing stage so suggestions, discussion and corrections are welcomed.
Needing components to attach the blue LED that will be added soon so no nasty for this omission please.
Nelson, thanks for sharing this wonderful amp that I’m sure will transcend time and be regarded as a classic.
hmmm... I like it. really simple. curious if the FETs are going to be too close together on the heatsink. maybe swing them out to be on opposite sides of the boards, and make the board a little longer to give them another inch or so. Just my thoughts. Beautiful nonetheless!
Definitely hoping a group buy happens with the final layout, whatever it happens to be.
-Jared
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Dennis Hui, Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.16702 seconds (63.88% PHP - 36.12% MySQL) with 11 queries
