F5 power amplifier - Page 251 - diyAudio
Old 27th January 2009, 09:57 PM   #2501
jackinnj's Avatar
Default Re: f5 pcb
Originally posted by umut1001
hi..my friend draw this for me..i wanna build f5 amp to 50cm of heatsink..for good cooling we decided to put the mosfets far eachother..what do you think about this?thanks
Always, always you want the gate stopper resistors mounted as close as possible to the gates of the MOSFETs.
Why, silly hare, are you fleeing from the fierce jaws of the lion now grown tame?
Old 27th January 2009, 10:31 PM   #2502
umut1001's Avatar
yes true.. i know shorter is better but for better cooling mosfets must be far eachother..its dilemma.i dont know what to do..
Old 27th January 2009, 10:34 PM   #2503
Magura is offline Magura  Denmark
Magura's Avatar
Copper just might do the trick for you.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 27th January 2009, 10:39 PM   #2504
umut1001's Avatar
sorry but i didnt understand
Old 27th January 2009, 10:57 PM   #2505
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
heatspreader made of copper
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 27th January 2009, 11:08 PM   #2506
umut1001's Avatar
ow i see..but its expensive and non findable here maybe i can find but i need to look for it
Old 27th January 2009, 11:10 PM   #2507
jackinnj's Avatar
It really isn't an option -- if the distance from the resistor to the MOSFET gate is too long the device can break into oscillation.
Old 27th January 2009, 11:32 PM   #2508
JimT is offline JimT  Canada
You could solder it directly to the pin of the Mosfet.
Jim
Old 27th January 2009, 11:47 PM   #2509
labjr is offline labjr  United States
If the MOSFETs are connected by wires, would it be better to solder the wires than use connectors ?
Old 28th January 2009, 12:45 AM   #2510
Thought I'd post another few pics. I sprayed my chassis tonight so while the paint was drying I finished another few bits of prep work. There is still a little chassis work to do like feet and the front panel. However I think the soldering on the boards and PS is just about done.
The alu panel was an internal panel inside the case I am using for the amp. Made it very handy to mount the transformers.
I amp going dual mono with this one so hopefully it will pay dividends. More I do the more I believe that the PS is critical to nearly everything. Just as important as the "circuit".
Like mentioned above, I am mounting the mosfets directly to the heatsinks and running some wire back to the PCB. Hope it will work out ok. The wires are about 3-4" long, will probably be a bit shorter when I mount properly to the PCB on the chassis.
If anyone sees anything wrong in all this, let me know!!!!
Fran
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Copyright 1999-2017 diyAudio
