F5 power amplifier
F5 power amplifier
Old 27th January 2009, 02:03 AM   #2491
labjr is offline labjr  United States
Oh I'm mistaken. I have cvillers boards. They're both blue. I may use wires to move the MOSFETs farther apart though. I'll need to use wires on the thermistors too.
Old 27th January 2009, 03:11 AM   #2492
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
Originally posted by woodturner-fran
Also, somehow I ordered 47k instead of 47R for R13 and R14. The BOM is correct so no biggie there. I have only some very crappy carbon film 1/8W 47R here or a good number of nice Dale 100R. Which should I go with?
there is a big chance that you'll like difference - with dreky carbon ones ;
under condition that you can hear difference , at all ....
( just look what Papa is constantly putting in his baaad amps - nothing more than plain industrial quality .......... )
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 27th January 2009, 05:00 AM   #2493
EUVL is offline EUVL  Europe
> I understand you run the amp balanced. Did you experience more body and improved dynamics comparing to single channel?
It is difficult to say, as I only tried single briefly, but with the same increased bias and reduced voltage. There is no lack of dynamics even in single, but it changes the characteristics of the sound just a touch, like you change from Aleph to Aleph-X (or 2nd vs 3rd harmonics, that sort of change).
Peter is known for optimisation with PSU and passive components. So I am among all the others looking forward to your experimental findings. Pls keep us posted.
(I am using PRP 0.25W and 1W resistors, and MPC74s for source resistors, as in earlier photos).
Patrick
Old 27th January 2009, 07:54 AM   #2494
woodturner-fran is offline woodturner-fran  Ireland
Yes, while the boards are small - I see that with mounting them a little further apart and using wires means that I can place them very evenly on the neatsink. The boards are lovely quality.
Zenmod: So you reckon I should just go ahead and use the carbon film 47R? Is it ok that they are only 1/8W?
Fran
Old 27th January 2009, 09:12 AM   #2495
Zen Mod's Avatar
F5 power amplifier
Fran
they're certainly good enough ;
just be sure that resistor leads aren't made of kryptonite ........
Old 27th January 2009, 01:50 PM   #2496
nah, not krytonite! more likely the cheapest crappy stuff that could be found. I hope to do more tonight and get it running pretty soon!
Thanks for the advice.
Fran
Old 27th January 2009, 08:06 PM   #2497
umut1001 is offline umut1001  Europe
umut1001's Avatar
Default f5 pcb
hi..my friend draw this for me..i wanna build f5 amp to 50cm of heatsink..for good cooling we decided to put the mosfets far eachother..what do you think about this?thanks
Old 27th January 2009, 08:12 PM   #2498
Diomedian is offline Diomedian  Canada
Default Re: f5 pcb
Putting the MOSFETs far from each other isn't a bad idea (depending on your heatsinks), but why not use wires instead of making the board so large? It would at least be cheaper to make smaller boards...
-j
Old 27th January 2009, 08:48 PM   #2499
umut1001's Avatar
i dont know maybe to prevent the capacitance effect of the cable..nelson uses long pcb..
Old 27th January 2009, 08:59 PM   #2500
chrismercurio is offline chrismercurio  United States
chrismercurio's Avatar
Which have long traces?
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
