Old 26th January 2009, 09:22 PM   #2481
Would someone explain to me what the advantage is of this amplifier having a bandwidth to 500 khz. Is there a potential sonic improvement in the music? I know bandwidths to 60-70 khz are supposed to effect the high end dynamics, but 500 khz.
Thanks Tad
Old 26th January 2009, 10:23 PM   #2482
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Originally posted by labjr
Maybe wait for the B3 preamp.
When connected directly to the source (no attenuator) F5 offers the level of resolution I didn't experince before, adding any line stage, even passive, spoils the fun
Originally posted by EUVL
Firstly answer to Peter,
Thanks for sharing the info. I understand you run the amp balanced. Did you experience more body and improved dynamics comparing to single channel? At least that was my experience with GC amps.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 26th January 2009, 10:25 PM   #2483
The one and only
Nelson Pass's Avatar
Firstly answer to Peter, I have not tried IRF Mosfets for the F5, so I have to pass on this one. It is difficult to describe the difference btw Toshibas and Fairchilds. The bandwidth for both device types are similar, but the Toshibas just sound more natural.
I tried to increase gain to 20dB as this is what I have for my reference amps. I did mention earlier in one of my posts in this thread that the particular configuration of my balanced F5 was a touch on the bright side. Increasing the gain made it sound even thinner. But then I cannot speak for Nelson's version as published. I guess either you have to wait for his comments, or just try for yourself.
I increased gain by increasing the feedback resistor. This has probably the least consequence.
I haven't tried the Toshibas, but the IR's have a softer characteristic,
and more 2nd harmonic, either at low or high frequencies, depending
on how you balance the circuit. If you find the stock F5 a little
zippy, the IR's will tend to remove this.
The Fairchilds measure better and so I use them, but this is a
relatively trivial issue.
Old 26th January 2009, 10:29 PM   #2484
apassgear's Avatar
Yes, but IMHO it does nothing to improve the richness of sound, which is already not its strongest point.
Hi Patrick
Have you tested local rail decoupling?
I'm not complainig about low richness in sound but it could be a bit better.
BTW, I'm running the amp as an integral... no preamp.
Fairchilds on P channel IR on N
Old 26th January 2009, 11:29 PM   #2485
Ok fellas I have a problem... or to correctly state it, you may have a problem.
A while back I posted a BOM from mouser for the F3 and F5. Quite a few people have asked me for it or downloaded it from the Peter Daniel F3/F4/F5 thread. There is an issue though that should be noted.
1) The 1/4W resistors won't lie completely flat against the PCB - you would need much smaller ones to do that. Not mission abort stuff, but be aware that you may need to stand them up, which is what I did.
Also, somehow I ordered 47k instead of 47R for R13 and R14. The BOM is correct so no biggie there. I have only some very crappy carbon film 1/8W 47R here or a good number of nice Dale 100R. Which should I go with?
Fran
(PS: I'll post this on the F3/F4/F5 thread as well to hopefully let everyone know)
Old 26th January 2009, 11:36 PM   #2486
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Fran
Mounting soldier style for those dales is no biggie.
For the gate resistors, parallel 100ohms would net about 50 ohms. Close enough I would think. I would solder one on top of the other real tight, and then only try to stuff one lead through the PCB.
I order the wrong parts fairly consistently. Your not alone.
Old 26th January 2009, 11:53 PM   #2487
Just to add:
Boards are really neat - and small. These will be quite easy to fit in a chassis. I know now I'm gonna have quite a bit of room to spare in there when I'm done.
On a brighter note my PS fired up AOK tonight with lovely 25.2VDC unloaded. Just right I would think.
Fran
Old 27th January 2009, 12:33 AM   #2488
labjr is offline labjr  United States
Just to add:
Fran
I was actually surprised the boards were so compact. I Would have to liked the outputs a little farther apart.
Old 27th January 2009, 12:41 AM   #2489
F3 board will accept regular size resistors. With F4 and F5 I'm using Dale CMF50: http://dkc3.digikey.com/PDF/C091/P1890.pdf
If you want to fit regular size resistors, just install them vertically, that shouldn't make any difference.
www.audiosector.com
Old 27th January 2009, 12:51 AM   #2490
Looks can be deceiving, the output devices are actually spread further apart than with the other boards: http://www.diyaudio.com/forums/attac...amp=1229205342
Besides, there are 4 mounting holes that allow board installation without mosfets attached and you can spread them as you wish, using wires. And that's what I call truly universal board, as some people might actually prefer it more compact, and I made it as compact as physically possble
That format is specifically convenient when you want to install the board between two heatsinks set approx 3" apart; in that case the distance between 2 mosfets (like in F5) doesn't matter at all, only placement on a heatsink.
www.audiosector.com
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Dennis Hui, Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.18062 seconds (66.02% PHP - 33.98% MySQL) with 11 queries
