F5 power amplifier
F5 power amplifier
Old 26th December 2008, 11:41 PM   #2391
hayenc is offline hayenc  United States
hayenc's Avatar
Send a message via Yahoo to hayenc
http://www.diyaudio.com/forums/showt...hreadid=134554
There was no definite answer. Many of us have had success with many vendors.
Actually, there was a recommendation to take the discussion to a new thread as some of the content in that thread was bordering on inappropriate speculation with some undesireable overtones.
I would suggest we also follow the recommendation there that this thread stick to what are the appropriate ratings for an F5 and if we want to do an objective comparison of the merits of various vendors, we move it to another thread.
Old 27th December 2008, 12:54 AM   #2392
labjr is offline labjr  United States
If things like brands of MOSFETs or changing a resistor value change the sound of the amp dramatically, probably more so than in the X circuit, then I would think there are subtle or even audible differences caused by changing power supply components in this amplifier. Now, from reading Nelson's posts on the F5 it seems he does a bit of a balancing act with different brands of components to get his amplifiers sounding right. In the end, when he tweaks the amplifier, it has a Plitron transformer in the power supply. I'd like to know if other transformers change the sound.
There's nothing wrong with discussing transformers in this in this thread because it pertains to using the transformers in the F5. I have concerns about how they will sound in this amplifier before I go and spend money on transformers. Just because someone sells inexpensive transformers that seem like a good value and he's a nice guy doesn't mean I can't question the quality of them for use in this amplifer project. If there were no differences, I would certainly use them. But I'm not convinced that there aren't.
Old 27th December 2008, 01:36 AM   #2393
udailey is offline udailey  United States
Passive Aggressive
F5 power amplifier
Well, if you were to buy two transformers... a Plitron and maybe an Antek and make sure they are same voltage same VA you could do an easy check. I only throw this out there because it is a feasible thing to do. Its expensive but on the other hand if the Plitron sounds better then you have a great transformer to use with a chip amp and the other way around as well. Transformers do not usually go to waste
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 27th December 2008, 02:18 AM   #2394
hayenc's Avatar
I've got no problem with discussing the transformers as they would function as installed in the amplifier. Let's just stay away from comments about the vendors or the country of manufacture unless we have solid evidence that such things change how the transformer works in the amplifier.
Old 27th December 2008, 03:36 AM   #2395
pchw is online now pchw  United States
F5 power amplifier
Hey, why not do us a favor, buy both transformers to try and let us know your opinion and some measurement data as well. You seem to have more interest in this regard than most of us.
- Fred -
Old 27th December 2008, 04:19 AM   #2396
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
Originally posted by zettelsm
... F5 ... point to point wiring ... or lead to lead?
Any downside to placing the power FETs at the optimum spacing/location on the heat sinks and using short jumpers to connect them to the rest of the circuit at the perf board?
I have built F1 by point-2-point wiring successfully. Based on that experience, I presume that it would applicable for F5 too. I'm 100% sure.
I support the optimum FETs location using short jumpers. Actually, my F5 has this arrangement.
I don't suffer degradation of high frequency response due to the stray capacitance or the lead inductance which is formed with the rather long leads . . .
Old 27th December 2008, 05:52 AM   #2397
zettelsm is offline zettelsm  United States
zettelsm's Avatar
Default P2P wiring, etc
Thanks, Babo!
Steve Z
Old 27th December 2008, 12:52 PM   #2398
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
F5 power amplifier
Default Trafo's.
Let all transformers be accepted.
Let all DIY be accepted.
Old 27th December 2008, 01:12 PM   #2399
umut1001 is offline umut1001  Turkey
umut1001's Avatar
all of us grandchild of Eva and Adam..we are all brothers too diy brotherhood forever
Old 27th December 2008, 01:13 PM   #2400
Tea-Bag's Avatar
F5 power amplifier
Default Chassis Design Question.
I am thinking about doing an F5 chassis without using the typical enclosure.
Let's call it an open air design, with heatsinks running vertically, and no top or 'hood' on, and possibly no front or back....
Knowing that the FET's and JFets are somewhat thermally sensitive, will the unit run potentially unstable if they are running in a somewhat open way?
I was then thinking that covering the jfets with a dollop of silicone may help here.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2017 diyAudio
