| Thread Tools | Search this Thread |
#2291 | |
what voltage appears on the output of the rectifiers if the mains voltage varies? Here in the UK the tolerance is 216Vac to 254Vac. If you use a 230:18Vac transformer on the standard UK voltage it will measure ~18.8Vac when fully loaded. On 254Vac it will measure ~19.9Vac when fully loaded. when unloaded these voltages will increase by the transformer regulation percentage. Big toroids can be as low as 3%, small EI can be as high as 30%. Find out the regulation of your transformer and adjust the output voltage assuming the PSU output fuses have blown and the caps are now charging up to the peak AC voltage going through the rectifiers. Mains voltage variations can be surprisingly large and can overvoltage components if ignored. Measure and check, or easier, allow a margin on ratings for the variations that will occur. BTW, electrolytics are available at many voltages between 25Vdc and 63Vdc, common available are 35V, 50V and less common 40V. Finally, expect your PSU cost to be more than the cost of the amplifier and heatsinks.
regards Andrew T. |
#2292 | |
Also, using components in "close to limit" area compromises reliability of the amp and makes the whole thing dangerous, so please think again |
#2293 |
and what if the voltage regulator fails or has a tolerance on output voltage?
What about the smoothing before the regulator?
regards Andrew T. |
#2294 | |
Thankyou for the info, i have realised i can get the same part in 35V for not much more. I have decided on 2 x 100,000uf Rifa capacitors per rail, do you think this should be okay? |
#2295 | |
Right ! That's exactly why even that solution won't be very feasible in this case ...
#2296 | |
Sounds very good. |
#2297 |
Hi all.
I am a bit confused regarding the best voltage for rails, I seem to remember Mr Pass saying 25v rails are minimum and any lower every volt makes a difference, but then everybody uses 18v secondaries which after rectifiers, voltage drop etc gives approx 23.5v rails. Why not use 20v secondaries or even 22v ? What have I missed ? Thanks. |
#2298 | |
#2299 |
hi..today i built f5 amp with huge heatsinks..i used 2sk1530 and sj201. bias is 1,5a and i see 2,83volts on r3 and r4..but the sound is very low.my soundcard is emu1212m and has enough output.what is the problem? i couldnt solve it
#2300 | |
I would check it with a function generator and a scope before hooking it to a source and speakers. |
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| Dennis Hui, Bksabath |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| Page generated in 0.16977 seconds (60.18% PHP - 39.82% MySQL) with 11 queries |
