Old 16th December 2008, 08:49 PM   #2211
nicoch58's Avatar
are the same size of vinyl LP
my are 250x300
Sic58
Old 16th December 2008, 09:00 PM   #2212
I started on the casework tonight and I almost cried. I'm recycling a worn out fostex rack mount 8 channel digital tape recorder as the case for the F5. Although the thing came from a studio and the heads were worn out, it was a real shame to gut the thing out. It was a lovely piece of engineering. You wouldn't believe the number of screws and crossbraces in this thing. It must have cost a fortune to make!!
Anyway, it will make for a nice case. Depending on how hot this thing gets I may add a fan... so I will be leaving provision for that. Adding even a small fan on my mini-aleph made a fair difference, dropping the internal case temp by 10 degC and dropping the heatsinks by about 5 deg C. Brings them back from 60 to 55. Nelsons controller circuit worked a treat (thanks)
Fran
Old 16th December 2008, 09:11 PM   #2213
nicoch58's Avatar
if you dont have metal shop near ,you can tray single part here
http://www.modushop.biz/ecommerce/cat099_l2.php?n=1
for top and front
Sic58
Old 16th December 2008, 09:17 PM   #2214
I hve visited that website loads of times intending to buy a case there but it just never worked out, or I recycled something else to suit.
They seem very fair in their prices both for the cases and shipping...
I might just fit a wooden front to the amp but am a little concerned as to how it would hold up to the heat. Maybe a little spacer would help a bit with that.
Fran
Old 16th December 2008, 09:19 PM   #2215
nicoch58's Avatar
this link
Sic58
Old 16th December 2008, 09:40 PM   #2216
labjr is offline labjr  United States
Originally posted by kierownik
hello
i planning to build a 10 channel amp, and i was wondering if i could stuff 5 F5 boards in to single case (how big the transformer would have to be?) or should i do 5 dual mono blocks?
I don't know how you'll fit ten chanels in one case. That will be one large amplifer. Maybe you could make ten monoblock modules each with it's own transformer.
Old 16th December 2008, 10:52 PM   #2217
Jeez, 10 channels! and i'm worrying about the heat that 2 will throw out!
Maybe you should consider going to forced cooling - might simplify the build and make it a bit smaller.
Fran
edit: nichoh - nice, I like that carbon fibre. Maybe as a front on its own. Right now though I think I'm gonna get some figured wood and maybe inlay it with some metals.
Does anybody know where I might get a latching push/push off type switch that will handle the current draw of this amp. Looks not really important, just that it works and is preferably 2 pole?
Old 16th December 2008, 11:19 PM   #2218
enzedone's Avatar
Default Fran
1) Switch: I had the same problem, so i am going to use a soft start
2) Wood panel: I am also using a wood panel and was worried about the heat so I put some small washes to space the joins out a little.
I realized that a major part of my job was to figure out how to use technology control to create economic force, or leverage, such that money and business flowed in Microsoft's direction” — Alex St.John, father of DirectX.
Old 16th December 2008, 11:49 PM   #2219
kierownik's Avatar
I'm getting this case
it's dimensions 485w/350d/180h
Old 17th December 2008, 12:02 AM   #2220
That looks nice. Where are you getting it from?
Does it have enough heat sink?
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
