#2201 |
OK, I'll go bigger.....
Thanks for the help, I know its a question thats asked loads.... probably because we are all looking for the cheapest way out of the heatsink problem. Many thanks...... Fran |
#2202 | |
The first is fairly standard with audio grounds tied in he amp and the power supply grounds tied in the power supply. These are then connected through the power cable. The chassis grounds are connected through an external banana plug so that they are both 'behind' the disconnecting network. EDIT: Deleted second image due to it being completely wrong!
#2203 |
Nichoh46: thanks for the suggestion - I had looked at RS, but they didn't come up in the search. I looked at farnell, but as it turns out now RS are cheaper for the transformer too so now I will build a dual mono one with 2 x 160VA transformers and bigger heatsinks for the same $$.
Thanks, Fran |
#2204 |
The power supply is the place for your "Star Earth" and is okay, but the second star earth in the amp case combines all the speaker return currents with the amp 0volt reference points plus adding noise to the input shields - this (IMO!) is where it's better to run them seperately back to the p/ supply star earth [the chassis earth is okay].
Mind you, many amps do exactly as you have drawn and it works just fine - in fact, the original F3 (for example) has a very similar setup to your schematic but all in the one case and there's no problems at all. Suggest you just assemble both cases and if there's problems, split the earth returns then. If you want to do the multi wire method, there are some excellent mutlipin plugs but none of them are cheap!
... jh |
#2205 |
Formerly "jh6you". R.I.P.
I have thought that this way is also acceptable.
Seasons Greetings,
#2206 |
http://uk.rs-online.com/web/search/s...-7034&x=23&y=9
there is 300x300 too http://uk.rs-online.com/web/search/s...duct&R=4907040
Sic58
#2207 |
Yeah, I bought the 300x300 type. Its a reasonable price for them....
Fran |
#2208 |
hello
i planning to build a 10 channel amp, and i was wondering if i could stuff 5 F5 boards in to single case (how big the transformer would have to be?) or should i do 5 dual mono blocks? |
#2209 |
The one and only
Ground loops are one of the problems that you will tend to enjoy with
10 channels. I recommend 10 little transformers making 10 isolated supplies that share a common chassis earth ground through resistors. This way you can make it pretty quiet without special effort.
#2210 |
Thanks for the replay, and what should be their wattage?
Could i go for 5 with dual secondaries? |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
