F5 power amplifier - Page 220 - diyAudio
Old 15th December 2008, 08:28 AM   #2191
estman is offline estman  Estonia
Default Re: toshiba mos
Originally posted by umut1001
hi..do i have to change any resistor value on the circuit if i wanna use 2sk1530/sj201 ? thanks
Yes, certainly. R3 and R4 smaller as Toshiba mosfets have Vgs ~1/2 of IR & Fc counterparts. Be careful not to overbias Toshibas, P1 and P2 can help you.
Old 15th December 2008, 09:46 AM   #2192
Default Seperate case earthing problems
Phresh,** To do the earthing properly, there are a lot more connections than you'd think - can reduce it as you want, depending on results.* It makes an enormous difference to the amp's performance if you go to some trouble to get it "right".*** +/- /0 (Rails) X 2 =* 6 wires (from Power caps - the 2nd ones in a C-R-C or C-L-C system)*** 0V for each speaker (- ve) return to Power Caps = 2 wires** *** 0V for input (signal) shield = 2 wires (maybe 1 with resistors) to P/Supply Central Earth *** 0V for amp chassis to P/Supply Case Earth (ground connection, RF reduction, etc)[6 + 2 + 2 + 1 = 11 total)* ** Have I left any out?** If you use a regulator in the amp case, you will want 2 more seperate 0V links to the Central Earth point. ** Inside your P/Supply, the Central Earth (Star) point is usually at the Power Caps -ve (or near to it) and all the "earth wires" go to this - but not always, unfortunately.*** ** Central Earth point is often "raised" from the ground connection via a resistor, diode or, here, a CL60 device.* Now, just how well all these earth connections really work depends a lot on how you actually pull them together and this has been an extraordinary point of argument over the years, so I'll not add to it here - many of us have very different ideas about "how good is enough" and this directly effects how many wires you want to use for this seperate box. ** I* remember AndrewT has a rather good diagram some time ago that very clearly showed the different links between supply and amp - perhaps, if this is still available ....?
Old 15th December 2008, 10:09 AM   #2193
Sorry -
To do the Earthing properly, there are a lot more connections than you'd think - you can reduce them as you want, depending on the results and it makes an enormous difference to the amp's performance if you go to some trouble to get it "right"
+/-/0v Rails X 2 = 6 wires. Speaker -ve returns = 2 wires. 0V for inputs, shields, etc = 2 wires. 0V for amp case to P/Supply case (gnd, RF rection, etc). Total = 11 wires
If you use a regulator in the amp case, add another 2 X 0V wires.
How well all these earth connections work depends on how they all come together, and this has been the source of considerable argument over the years - there really isn't any one "correct" way and many of us have very different ideas about "how much is enough" - it gets quite expensive, too.
Perhaps if AndrewT reads this thread and could post up the very clear diagram about Power supply circulating currents, earth loops, etc, that he did awhile ago .....?
That's a bit better - I'm not fond of these small size Gyration keyboards - a real pain in the ....
Old 15th December 2008, 11:36 AM   #2194
phresh is offline phresh  United Kingdom
Cheers, i'd completely forgotten about the grounding thread so managed to find it with a search.
My biggest issue was whether to connect the signal grounds to the chassis in the amp along with the power supply grounds. From a diagram in the aformentioned grounding thread it seems best to pass all grounds back to the power supply and connect them there and then pass the mains earth to the amp chassis. If that makes sense anyway!
This did make me think of how Naim build their equipment where all grounds are passed back to the power supply.
Old 15th December 2008, 08:23 PM   #2195
umut1001's Avatar
Default about feedback resistors
hi..today i bought some pieces for f5 amp..for feedback i have noname 100ohms metaloxide and 100ohms hitano wirewound resistors..which one is preferable?amp has big input empedance and someone says it causes oscillation..maybe wirewound ones cancels the oscillation?
Old 16th December 2008, 12:41 AM   #2196
Yeah, Phresh,
The grounding ideas can be quite confusing - I think of it as.... any wire that contains power current (rails, speaker returns, potential chassis earth currents, etc) should be seperate from any signal wire, and their shields - high probability of "ground loops".
Now, if you take this a step further, you seperate the power rails (supply) and amp speaker wires (output) - this is just better power distribution and returns - obvious, really.
This results in the 3 seperate and distinct groups/types of earth wiring, okay?
When you have a seperate p/supply case, add another one that keeps both cases tied directly to the mains earth connection, not the "star"earth on the supply, with everything else.
The same thing applies with preamps, Xovers, etc, even tho there isn't large currents - the "ground plane" needs to be much cleaner.
The idea of using balanced line level signals can be quite useful but also produces it's own problems and even more connections!
Old 16th December 2008, 08:50 AM   #2197
What do you guys think about this heatsink?
farnell heatsink link
Fins 40mm (1 1/2") with 10mm (3/8") thick base plate, 100mm (4") high and 300mm (12") long
Its rated at 0.4 degC/w which I know is a wee bit high but the next one up is $$$ more. Its also a very reasonable size to fit in my rack and it won't be as tight a fit between the shelves...
Is it reasonable to mount Q3 and Q4 out to the very tips of the their legs to spread them out as far as possible on the heatsink (12" long) or will that cause problems (using the Peter Daniel boards)?
Fran
Old 16th December 2008, 09:02 AM   #2198
RS component have aavid 300x250x40 at 40€ or 300x300 at more two€
Hope this helps
Old 16th December 2008, 09:16 AM   #2199
So do you think I need the extra size?
Fran
Old 16th December 2008, 09:56 AM   #2200
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
You will be operating the heatsinks at a lower temperature difference level than what is used to measure their thermal resistance factor.
Means the heatsinks will be less efficient in your application, you need a bigger one to obtain the same C/W value.
Secondly, the thermal resistance factor of a heatsink also depends on the altitude it is used at.
Way up the mountain, the heatsink thermal factor will drop significantly again because of lower air pressure, some 20% lower efficiency at an altitude of 10.000 ft compared to sea level.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2017 diyAudio
