Old 4th December 2008, 09:25 PM   #2111
I would also be interested in a board.
I recall there was mention that at some point in time PASS DIY would be offering F5 boards for sale. Perhaps that has fallen by the wayside?
Old 4th December 2008, 11:12 PM   #2112
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Does anyone know which issue NP does a write up in AudioXpress on the F5?
Old 4th December 2008, 11:24 PM   #2113
udailey is offline udailey  United States
Passive Aggressive
I just shot you an email. But nevermind it. Here is a link to all you need to build it.
http://www.firstwatt.com/downloads/F5-om_sm-080527.pdf
Uriah
Old 5th December 2008, 01:08 AM   #2114
Default another one sided F5 board layout
here is yet another layout. 137mm x 51mm (5 x 2 inches)
Old 5th December 2008, 01:50 AM   #2115
rdk845 is offline rdk845  United States
Default firing up but fuse blowing
please help a newbie... I have made one up with p to p using the Juma's lay out. I have reduced the P1 and P2 value to minimum ( they are 1-5 ohm now) as stated in the Nelson's article and used variac to slowly move up the AC. The fuse blows up before rail voltage reaches 2V.. If I disconnect +- 24 and ground from main board, rail voltage reaches 26V no problem... It appears to me that if P1 and P1 is minimum value all the voltage is applied across JFET. Is this O.K.? What am i doing wrong? I'm using psu board from peter daniel and it seems psu is o.k...
Thanks!
Old 5th December 2008, 03:06 AM   #2116
bluemartini's Avatar
The raw parts are fairly easy to find in the USA. He supplies 10K for for R21-22. I thought I read somewhere that those were changed to 22K ?
You did its back at post 1948, so you would have to replace the 10K provided.
Old 5th December 2008, 05:36 AM   #2117
cviller is offline cviller  Denmark
cviller's Avatar
Default Re: firing up but fuse blowing
Originally posted by umut1001
we can make single sided pcb ourselves..a double sided board will be better for group buy if Nelson permits....and we need fairchild output transistors..i am agree for group buy
Haha. Are you guys serious? The number of layers is quite irrelevant - you can make the most absolute horrible layout using double layer if you want to. I have used a single layer because no more is needed for this application (when I do phono stages and digital circuits I usually make a ground plane as well). If I had to get the boards manufactured, I might throw in another layer to reduce board size, but then the old farts in here might have troubles stuffing the boards.
Thanks!
Sounds like you have a short or have connected your power fets wrongly (if connected wrong, they are just power diodes). Try monitoring the voltage across the source power resistors (r11 and r12) when you turn up the voltage slowly. Otherwise post some detailed pictures and people in here might be able to help you.
Old 5th December 2008, 05:49 AM   #2118
steenoe is offline steenoe  Denmark
steenoe's Avatar
Default Re: Re: firing up but fuse blowing
Originally posted by cviller
Haha. Are you guys serious? If I had to get the boards manufactured, I might throw in another layer to reduce board size, but then the old farts in here might have troubles stuffing the boards.
LOL
Old 5th December 2008, 09:12 AM   #2119
thermos is offline thermos  Australia
The PCBs I would like would be PassDIY F5 PCB's.
That would be cool.
Old 6th December 2008, 02:13 PM   #2120
jackinnj's Avatar
I am now including 22k1 in the parts kit for the F5.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
