F5 power amplifier
F5 power amplifier
Old 14th November 2008, 01:32 PM   #2031
estman is offline estman  Estonia
Originally posted by zinsula
But Toshiba MOSFET's are not laterals...
Tino
Yes, Hitachi make laterals. And Toshiba mosfets have high transconductance.
Old 15th November 2008, 12:09 AM   #2032
enzedone is offline enzedone  New Zealand
enzedone's Avatar
Exclamation Sorry
Sorry for trying find out how to build one of these amps
Sorry for posting only three questions in this thread and only getting one answer(AndrewT).
Sorry for interupting all the anal geeks who don't wish to actually build anything. Just wish to discuss 'possibilities'
I'll just go elsewhere and buy a board off 'someone else' doesn't worry me in the slightest.
Maybe there should be a separate thread for people who just want to get this amp built. And are not interested in discussing how one particular part may sound .00001% better if it's replaced and facing 'north east' and the amp is switched on at 3mins past sunset on friday's at 25.575 deg above ambient room temp with a RH of 50% in December.
I realized that a major part of my job was to figure out how to use technology control to create economic force, or leverage, such that money and business flowed in Microsoft's direction” — Alex St.John, father of DirectX.
Old 15th November 2008, 12:38 AM   #2033
apassgear is offline apassgear  Mexico
apassgear's Avatar
Default Re: Stupid Question
Originally posted by enzedone
Is the track layout correct for P1 & P2?
Hey Enzedone, lighten up, everybody seems to be in his own wave here, sometimes this happens.
Your tracks for the trimpots looks OK to me.
Old 15th November 2008, 01:02 AM   #2034
flg is offline flg  United States
flg's Avatar
Default Re: Sorry
... anal geeks...
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 15th November 2008, 01:43 AM   #2035
enzedone's Avatar
Thumbs up Thank you
Thank you & good night
Old 15th November 2008, 07:10 AM   #2036
juma is offline juma  Germany
juma's Avatar
They are very complementary verticals, with low Vgs threshold.
Tino
Hi Tino,
you are right - I stand corrected. Somehow, when I see 2SK or 2SJ mark i seem to automatically think of Hitachi's 2SK135 and 2SJ50 - the first power MOSFETs I used - decades ago....
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Old 16th November 2008, 12:19 PM   #2037
thermos is offline thermos  Australia
Default Stupid Question - P1 & P2 Adjustment
Before I switch it on.....
I am reading the F5 manual, under "Initial Adjustment".
"you will want to set the values of P1 and P2 to their minimum. Verify this with an ohmmeter"
Just to clarify, does this mean I want to initially set P1 & P2 to be 0 Ohms (or the lowest it will go)?
Thermos
Old 16th November 2008, 12:41 PM   #2038
stein2 is offline stein2  Serbia
stein2's Avatar
Default Re: Stupid Question - P1 & P2 Adjustment
Thermos
Yup! zero ohms. Be sure to consider the output DC zero as the most relevant, and measure the volts across the resistors at output devices , the voltage at the input will not affect the final results. Not really important, it's important to get zero DC volts at the speaker output.
"Calculations? We don't need no stinkin calculations! We just make them really big!" - Papa
Old 16th November 2008, 12:44 PM   #2039
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
According to my approximation, we will have final values of P1 and P2 at about 1K+something. So, I highly recommend you to start P1 and P2 values lower than 1K.
Be careful, if you have too high P1 and P2 values, the bias current easily goes up more than 10A . . . No good, even if the amp has the current limiter at 10A . . .
Good luck!
Old 16th November 2008, 12:48 PM   #2040
Thanks Stein2
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
