Old 22nd September 2008, 10:36 PM   #1811
hc167 is offline hc167  United States
point to point is good too. I just want to be as professional as possible. Well, maybe I should re-think about it. plus point to point is almost always cheaper.
Old 22nd September 2008, 10:49 PM   #1812
...truth seeker...
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Default cheap?...who's cheap?
hc167,
You could do a lot worse than check here for parts:
The Company Store
Take care that he has had his morning coffee 1st
Old 23rd September 2008, 10:30 AM   #1813
Default point-to-point option
Can get the 'vero' board everywhere - the fibreglas board with all the holes and no copper - perfectly good option to pcb and often better.
... jh
Old 23rd September 2008, 06:49 PM   #1814
this is what I am thinking now. actually, I may consider using only one broad for both channels. that way I can reduce the amount of cable from power supply to the broad, and that end up having better physical component arrangement in the amp (If I do everything right). Since F5 has simple circuit design, I think point to point is good way of build it.
Old 23rd September 2008, 07:05 PM   #1815
khaho is offline khaho  Finland
I am quite a newbie, but I see two problems in one board for both channels:
1) the current needed from PSU is doubled with less wires and thats quite demanding for full power of F5 (this could make channel separation worse at high power)
2) cooling arrangement is worse, you need really big one heatsink or the board must be between heatsinks, making the size of the board quite fixed for a case of some size (you should not have long wires to gates of the mosfets, or gate resistors should at least be near the mosfets)
Old 23rd September 2008, 07:25 PM   #1816
Thanks a lot for your comments. Well, first, the current will depend on how you arrange your component on the broad and the wire that you use. So I do not think I will worry too much about it. Second, I said I will use one broad, but I never said I will mount the power devices on the broad. In stead, I think the device should mount on the heatsink directly and separate from the broad. The reason why I think this way is I build a Aleph 30 before and from my experience, problem with power device on one broad is the broad will get hot too. Especially we are building a class A amp. So I want to let all the component as cool as possible. I guess the best way to do is not to mount the device on the broad. yes, it is little more work. but I think that is ok. plus I am not good at drilling hole on heat sink. so good thing about this design is I only need to drill and tap two holes for each channel. drilling holes on heat sink and then tap is just too painful for me.
Old 24th September 2008, 06:05 AM   #1817
oh, by the way, Mr. Pass, you mentioned you will have the broad available for sale sometime on the passdiy.com. Did you change your mind not to go for sale?
Old 24th September 2008, 07:21 AM   #1818
tommak is offline tommak  United States
Default "Broad" for sale?
Mr. Pass, when you start selling the "broad" on passdiy.com, I'd like a cute, blond one please!
Old 24th September 2008, 08:41 PM   #1819
The one and only
Nelson Pass's Avatar
Everything takes time. Lots of time.
Old 24th September 2008, 10:29 PM   #1820
Blues is offline Blues  United States
Lightning In A Bottle
Blues's Avatar
It will be one hot broad ...I hope there'll be enough for everyone.
Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2013 diyAudio
