Old 26th August 2008, 07:08 PM   #1671
udailey is offline udailey  United States
Passive Aggressive
Great Thanks Mr. Pass.
Uriah
just got these and will use .5oz stuff for any preamps
http://cgi.ebay.com/20-lbs-Copper-Cl...742.m153.l1262
Thanks again
Old 26th August 2008, 09:10 PM   #1672
ChuckE is offline ChuckE  United States
Default two newbie questions re F5
1) Is it possible to raise the F5's input impedance so as to make it even friendlier to a delicate tube preamp? (Mine likes a 470k ohm input impedance on an amp). What would be the effect on the F5's performance of doing this?
2) Could one use paper-in-oil caps in the power supply? I know a diy'er who swears by them, even in the power supply, for imparting a rich, full, warm sound.
Thanks.
Old 27th August 2008, 02:46 AM   #1673
Default f5 amp
its the fairchild set that increases the output ,I mentioned that for the sake of completness.whether that is material is moot, I should mentionwhen I put a cap on the front the output goes to zero. Even so I am still not satisfied and will investgate further
RW
Old 27th August 2008, 05:01 AM   #1674
enzedone's Avatar
Default TH1 & 2
Could someone please confirm if these are the correct thermistors that are to be placed in series with R15 & R16.
http://newzealand.rs-online.com/web/...duct&R=1912257
Brett
I realized that a major part of my job was to figure out how to use technology control to create economic force, or leverage, such that money and business flowed in Microsoft's direction” — Alex St.John, father of DirectX.
Old 27th August 2008, 06:40 AM   #1675
enzedone's Avatar
I have also found a site for the following. Which has a minimum order of 20.
http://www.ampslab.com/trans_2sj74bl.htm
What I'll do with 40 of these, but if that's what it takes to get this amp built.
Sorry for asking so many questions, but I'd rather check with someone who know's more than I do.
Old 27th August 2008, 09:07 AM   #1676
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Brett,
if you are only after 2 pairs of J74/K170 you could ask if someone has some spares for you.
PayaPalling a few dollars is easier on the wallet than shelling out $40 and be stuck with $36 in parts you don't have a destination for.
Maybe you should ask the right question.
Looks like Sponge Bob has killed another thread.
Old 27th August 2008, 09:18 AM   #1677
enzedone's Avatar
Default Quite right
I have purchased a couple of chips from here before, and just happened to go back to have another look. I found a good deal on some parts for the F5.
http://tech-diy.com/inside_tech_diy.htm
I couldn't get get these here for this price and matched as well great stuff........
Brett.
Old 27th August 2008, 12:57 PM   #1678
Passive Aggressive
ChuckE,
You might consider building the supply on the last page of the F5's operating manual.
http://www.firstwatt.com/downloads/F5-om_sm-080527.pdf
If you go to www.apexjr.com you can get 12,000uf caps for 1.99 each. The PIO caps will NEVER have enough capacitance to work well in the power supply for this amp unless they are the size of a broom closet. You could use them to snubber the supply though.
Uriah
Old 27th August 2008, 01:02 PM   #1679
Passive Aggressive
Brett,
I had similar questions about TH1 and TH2. From the answers I received I think that the thermistor you found will work fine. It seems that the wattage it is capable of really doesnt matter much and you are at 4.7k so that should work fine. I have mine 90% built for some reason and not 100% so I cant say that mine fired right up no problem yet. However, I could also add that Nelson says in his paper on the F5 that the Thermistor is not necessary and a few people have left it out of their amp, replaced by a resistor. So I think you can count yourself safe with that Thermistor.
Uriah
Old 27th August 2008, 08:11 PM   #1680
estman is offline estman  Estonia
Default Thermistors - goodbye
I measured IRFP244/SFH9240 @ 1,15A. And the results are good news: the tempco is negative for both.
Happy building without thermistors !
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Dennis Hui, Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.19599 seconds (71.89% PHP - 28.11% MySQL) with 11 queries
